Reese Hitch
Ones that I have used were model specific.
You should cross check the model number of the hitch between the two
Different trucks.
Frame width and mounting points may vary.
An F150 hitch that I installed once had a notch to avoid a bolt in the
Frame.
Or
If the hitch is available, mock it up to see if it fits.
Different trucks.
Frame.
Or
Check out this item I found on eBay:
2006-2008 LINCOLN MARK LT PICKUP, 2006-2008 FORD F-150
Link: http://www.ebay.com/itm/2006-2008-LI...-/180713370075
Try this, its made for your truck
Go to U-Haul and get theirs for $100-150
Go to any parts store and get the proper Reese for maybe $200
Trust me, that money you "saved" will be spent trying to adapt that hitch...and ultimately it won't be nice looking or worth the headache
The Reese hitch for a Chevy won't work on the F150. They mount up differently. Why would you want to spend $50 on a hitch that reqired $200 worth of fab work to get it to fit. Buy the correct hitch to start with and you'll save a lot of expense and headache later. You can get the proper hitch from most parts stores or an RV supplier for around $200-$250 new. Do it right the first time and don't worry about it again. You may also be able to find a correct used hitch at your RV supplier that does installs.
Although come to think of it would it be more practical for light duty towing just to get a $10 bumper ball from Harbor Freight and be done with it for now? the bumper says 5000lb capacity whereas a Class III hitch without the weight distribution is 6000lb. So I should be easily able to pull a pop up camper off the bumper.
Locally we can rent a 1 yard cement mixer from Ace Hardware.
They were very specific on ball height, I had to add a couple of bags
of concrete mix to the rear of my Bronco to get it to the proper height.
I know that the bumper can handle the basic towing needs, but it is up
to our own judgements on how to do it..
I have used the bumper hitch on many occasions with many types of smaller/
lighter trailers with no problems.
Experience counts, personally and with other peoplesʻ input.
FilmGuy
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-11-2020 05:34 PM
tbmitchell06
05-30-2011 09:20 PM
DJChunter
01-22-2004 05:56 PM
