Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-13-2012, 12:47 AM
cws10190's Avatar
cws10190 cws10190 is offline
Garage is empty, add now
cws10190 is starting off with a positive reputation.
c4ae-g heads
i got a set of these heads and i need advice on what to do with them. so far i called a local shop and the guy said for 800 he would machine in hardend valve seats bronze valve guides, port match and polish exhaust and port match my intake to intake manifold, install new parts? i have new comp cams valve springs and lifters, retainers a,nd cam, 268 duration 494lift. what i need to no is if i need to get new rocker or if the old stuff will be okay. its a hydr flt tppt cam. he will do bowl work too. so basically im asking if this is al i need and if not what else do i need to make sure it runs efficiently.
  #2 (permalink)
Old 04-13-2012, 07:35 AM
baddad457 baddad457 is offline
baddad457 has a good reputation on FTE.baddad457 has a good reputation on FTE.
You don't need an $800 head job (OK, that sounds funny) for that cam. Just a basic rebuild will do with the stock rockers and springs
__________________
89 Ranger supercab-- 302-4bbl-- 4 speed 68 Mercury Monterey 390 4 bbl C-6 77 F100 400M C-6 67 Mustang fastback 427 2-4
  #3 (permalink)
Old 04-13-2012, 10:06 AM
cws10190's Avatar
good i didnt want to upgrade rockers yet, but im going to put this motor in a stang in the future so im going to get as much done to the heads as possible while there off. when it goes in the stang im going to put alot bigger cam in it. but for now its going in the truck agian so i can smoke all these new trucks around here, not that it already wouldnt, lol make my moms 6 speed hemi look like a 4 cylinder
  #4 (permalink)
Old 04-13-2012, 02:28 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Quote:
What about the valve seats?
  #5 (permalink)
Old 04-13-2012, 05:53 PM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
Have the oil passages camfered and install the hardened valve seats. Your engine will thank you and save you money in the long run.
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #6 (permalink)
Old 04-13-2012, 09:40 PM
puttster puttster is offline
puttster is starting off with a positive reputation.
Agree with poster that cam will (just barely) work with stock springs. C4 are about as good heads as you can get on a FE. If it needs a valve job might as well get hardened seats, otherwise not. But if you did, you could turn it into a CJ by putting in CJ valves, that's all you need to do for those C4 heads, or so I am told. Of course you can port and polish them too.
puttster
  #7 (permalink)
Old 04-14-2012, 01:18 AM
cws10190's Avatar
i have new comp valve srings, and im having cj valves put in it.
  #8 (permalink)
Old 04-14-2012, 10:37 AM
The new seats are a good idea, but the rest is really not required for a cam like the 268H. That cam will work with fresh stock 390 springs, new springs aren't a bad idea if they came with the cam kit. The port work and larger valves are not a requirement, you will need some port work done to take advantage of the CJ sized valves.
__________________
Tags
38, c4ae, c4aeg, flow, ford, heads, picture, rockers, stock, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
