360/390 questions
Old 03-29-2012, 07:26 PM
foggdog's Avatar
foggdog
foggdog is offline
360/390 questions
hey all new to the site and Im helpin out my brother (no computer) anyways he's got a 77 highboy with a 360/4 spd, we wanna do a longblock or crate engine install. So my question is what motors are compatible with his exsisting bell housing, does the 390 have the same bolt pattern. And if he decides to go crate motor (on a budget) what motor would you all suggest. I'll be here alot asking question, so thanks ahead of time. Im into the bike building scene and what do you think of the high hp 302 crate mtrs?
Old 03-29-2012, 08:33 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
390 +360 same block so that's the easy switcharoo
i did this to my 68 found a long block 390 out of a tbird and rebuilt it . with some extras.
Old 03-30-2012, 07:05 AM
foggdog's Avatar
foggdog
foggdog is offline
Thanks Mike, much appreciated.
Old 03-30-2012, 07:16 AM
baddad457's Avatar
baddad457
baddad457 is offline
Better make sure it's a 360 in there. The 77's had 351M/400's. Last year for the 360/390 in pickups was 76.
Old 03-30-2012, 07:26 AM
foggdog's Avatar
foggdog
foggdog is offline
Will do, I call him and let him know right now, ty sir Whats the best way to ID the motor ?
Old 03-30-2012, 07:45 AM
baddad457's Avatar
baddad457
360/390's valve covers overlap both the intake and heads. The 351M/400's do not and have 8 bolts per valve cover, the 360/390's have 5 bolts per cover
Old 03-30-2012, 07:52 AM
foggdog's Avatar
foggdog
foggdog is offline
Thanks again baddad.
Old 04-13-2012, 12:30 PM
yellow truck's Avatar
yellow truck
yellow truck is offline
You can't tell a 360 from a 390 based on external examination. You have to measure the stroke. There are lots of threads on that subject.
Couple of other things - why stop at at 390? You can't get much more bore out of an FE without checking the block, but you can get a lot more stroke. If you are buying a rebuild, it isn't that much more to get a stroker.
If you do get a long block, the motor mount positions were different between car and truck engines, but the mounting holes for both are present. Just don't wait till you are dangling the engine over the bay to notice. Also, some of the high performance heads came with four bolt exhaust manifold configurations. Trucks had two bolts, again you don't want to find that out when you are trying to mate your headers or manifold.
Last, 2WD engines had a front oil pan resevoir and pick up. The 4WD had them on the rear. You need to move the pan and pick up over to the new engine and move the front main bearing cap bolt to the rear because it has a bolt hole threaded into it to attach the pick up.
All in all trivial stuff. Last thing to watch out for, lots of shops can rebuild a 302 or a chevy small block, not that many builders know the FE. Look up FE oiling mods on this site, if the builder can't show you they were done, get your engine elsewhere. Buy your long block from a known FE builder and they will know the quirks of the FE. If you can, get an engine dyno on it before you take delivery. It costs a few extra bucks, but it will tell you everything you need to know about your engine.
Last thing, when you get your new engine in the truck, kick the crap out of it to break it in. Hard runs from zero to 60 back to zero for 50 miles, then change the oil and just run it hard for the first thousand.
Old 04-13-2012, 01:39 PM
66crawler's Avatar
66crawler
66crawler is offline
Yellowtruck I think they just need to make sure its an Fe motor first.
Old 04-13-2012, 02:19 PM
yellow truck
66crawler - true enough, however regarding the oil pan and pickup he has the same issue, it is a 4WD, so you need the oil pan reservoir at the rear. I have no experience with the 302 or 351, but they came in standard config with the reservoir and pick up at the front.
Old 04-13-2012, 02:26 PM
yellow truck
Another way to ID an FE is the plugs are set up / / \ \, which is unique among Ford engines.
Old 04-13-2012, 05:43 PM
69cj's Avatar
69cj
69cj is offline
Intake/head configuration is the easiest. Helen Keller could spot it.
Old 04-13-2012, 10:15 PM
kwe45919's Avatar
kwe45919
kwe45919 is offline
I want to laugh cause it's true, she'd spot it before half the others could....which makes me want to
Old 04-14-2012, 10:42 AM
baddad457's Avatar
baddad457
Well the fac that it's a 77 highboy changes everything. These trucks didn't come with an FE motor. So if it does have an FE, it could be anything as far as a car or truck motor.
68 f250
27
10-21-2020 09:27 AM
Big block 68
07-31-2012 08:01 PM
Scott-71f-250
05-10-2009 12:07 PM
77fordf-150
Minnesota Chapter
16
12-28-2006 09:45 PM
gcfisher75
06-22-2004 08:16 PM
Quick Reply: 360/390 questions
