c4ae-g heads
Old 04-13-2012, 12:43 AM
cws10190's Avatar
cws10190
cws10190 is offline
c4ae-g heads
i got a set of these heads and i need advice on what to do with them. so far i called a local shop and the guy said for 800 he would machine in hardend valve seats bronze valve guides, port match and polish exhaust and port match my intake to intake manifold, install new parts? i have new comp cams valve springs and lifters, retainers a,nd cam, 268 duration 494lift. what i need to no is if i need to get new rocker or if the old stuff will be okay. its a hydr flt tppt cam. he will do bowl work too. so basically im asking if this is al i need and if not what else do i need to make sure it runs efficiently.
Old 04-13-2012, 09:34 AM
Conanski's Avatar
Conanski
Conanski is offline
'64 289 heads? Sinking bug bucks like that into vintage heads is never money well spent IMO when you can have brand new heads for around $1000 that will outperform these by a factor of about 3x.
Old 04-13-2012, 10:02 AM
cws10190's Avatar
cws10190
cws10190 is offline
they r 390fe heads, and my wife doesnt like the idea of me spending money on **** wen i already have it
Old 04-14-2012, 01:57 PM
Ken(Ark)'s Avatar
Ken(Ark)
Ken(Ark) is offline
Your machinist should have the heads set up for non adjustable rockers .
For $800 are you getting larger valves ? Porting and bowl blending will help a little but not really noticable without bigger valves . A .494 cam is better than stock and OK for a daily driver .
For $750 you can get heads with larger valves , springs , milled , etc , delivered to your door .
FORD FE 390 PERFORMANCE HEADS BY TUFF DAWG ENGINES | eBay
Old 04-14-2012, 06:58 PM
cws10190's Avatar
cws10190
cws10190 is offline
THATS bowl blend big valves hardend seat bronze guide port match and polish
Dr. Driveway
08-12-2015 02:14 PM
gyrhed
01-15-2013 01:47 PM
mikepedersen17
12-06-2011 10:14 PM
bb79ranch
11-12-2002 07:26 PM
Quick Reply: c4ae-g heads
