2002 Explorer 4.6L - dreaded P0340 code - Page 2 - Ford Truck Enthusiasts Forums
Old 05-07-2013, 10:10 AM
RRousta RRousta is offline
RRousta is starting off with a positive reputation.
Quote:
Originally Posted by dyoboiz88 View Post
im having the same problem also wondering if a clogged cat would cause back up to causing everything to compensate for the vct and cam sensor codes?? i had both replaced already it all started with a misfire in cylinder 6 but ran it with the misfire for a while then truck just went hay wire n would barely run and got a bunch of codes replaced all the coils n plugs cam sensor vct both sides cam sensors on both sides n that was all from ford n still have a problem with the p0340 code coming back only if i drive the vehicle for like 3 miles.... n then runs rough barely runs.. shut it off for a day start it up n runs fine for like 3 miles.... so if u figure out whats wrong let me know ill try it also... 4.6 mountaineer
i think we are dealing with another engine. Mine is a SOHC 2v 4.6. Don't have VCT, so i'm not sure what to tell you. Good Luck on your search though. I Don't think mine is a cat. convertor issue. The vehicle runs perfectly fine.
Old 05-16-2013, 01:49 AM
still haven't done or tried to do anything else to my truck, just been swamped.
for some reason, i may have some suspicion in the alternator again. I put a new re manufactured one in, but you never know. I was reading up on the 4.6L SOHC mustangs, and 95% of the time, its an alternator problem and lots of people have had their new re manufactured ones mess up right away.
Also, while reading the code scanner, when the revs are above 2000rpm, the code is no longer present.
I'm planning to take it to the dealer and have them have a go at it. I hope they'll be able to figure it out and it wont be ridiculous.
Old 05-23-2013, 10:12 AM
jammer815 jammer815 is offline
jammer815 is starting off with a positive reputation.
Did you take your explorer to the dealer? What did they determine was the cause?
Old 05-29-2013, 12:57 AM
Quote:
my truck is going to the dealer this week, will keep updated. I tried another alternator (used, but working), didn't make a difference.
Old 07-12-2013, 01:19 AM
well I guess I can say my truck is finally fixed thanks to the dealer.
It spent over a month there, and it sure made them scratch their heads.
The local dealer was puzzled, and checked everything externally and electrically on my explorer. Apparently they were going back and forth with Ford Engineering and being told what to do by them.
The end result: According to the dealer, The timing was off by one tooth, and the tensioners that was put in my engine were not the correct one.
I have the truck back, it seems to run good, if not the same but no more CEL. Cost me some pretty pennies. Hoping to take it for emission testing tomorrow
Old 07-12-2013, 10:01 AM
dyoboiz88 dyoboiz88 is offline
dyoboiz88 is starting off with a positive reputation.
RRousta well i got my mountaineer back yesterday got a new motor in it and the problem was the timing chain guide broke messed up my timing and pieces in side motor didnt help either... runs great now....
Old 08-08-2014, 11:20 AM
mamaMia mamaMia is offline
mamaMia is starting off with a positive reputation.
HELP i have a 2002 ford explorer just recently replaced transmission and fuel pump in march. first gas window wasnt matching gas hand then about a month later my truck stopped on me. a blue mini 15 fuse is being blown eveytime i try to start the truck. all lights and radio still work fine. had two diagnostics done one at a shop and the other at the dealership no answers now the dealership want to test my PCM. im already out of alot of money with towing and diagnostic fees! What should I do. they saying if i have to replace my pcm for everything it will cost 1500$
Old 08-09-2014, 11:04 AM
weross67 weross67 is offline
weross67 is starting off with a positive reputation.
Question Fuse Location
If you don't mind can you tell me which fuse box and the fuse number or location of the fuse in the box?
Thanks WER
1997 4.6L Barely runs P0340 Code bigdonward 1997 - 2003 F150 3 02-20-2017 04:39 PM
Can Codes P0340 & C1226 be linked ? saltydog463 1968-2013 Full Size Vans 7 01-15-2016 06:16 AM
2004 F150 5.4 P0340 Alec Blanchard Modular V8 (4.6L, 5.4L) 2 12-09-2015 10:47 AM
1997 Aerostar Check Engine Light MomsAerostar Aerostar 8 12-09-2015 04:16 AM
HELP - I am at my wits end - 05 EB Notrega Modular V8 (4.6L, 5.4L) 13 05-19-2014 04:28 PM
Tags
02, 0340, 2002, 46, camshaft, code, engiv, explorer, ford, lack, liter, mountaineer, p0340, power, sensone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
