HIO Silver's Lo-Buck Bumpside Build - Page 34 - Ford Truck Enthusiasts Forums
  #496
Old 07-21-2014, 01:31 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is offline
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Quote:
Originally Posted by HIO Silver View Post
I **might** have to settle for one in red. I already thought of a personalized license plate... 4REGAZM. Ya think that'll get a pass from the State reviewer? The other one is 4REU4EA.
Hope so. If you were here in AZ. you'd have to tell them a real innocent meaning.
  #497
Old 07-21-2014, 03:29 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Hey Jeff.. Yesterday I uncovered some part numbers while wire-wheeling the driveshaft... C8TA-4xx2-Fx.
I'd like to repaint the numbers after it's cleaned up but can't make out the characters in "x" above. Can I get some help from your microfiche? Thanks!
...70 F100 longbed 360FE/NP435/Ford 9-inch with a two-piece driveshaft.
  #498
Old 07-21-2014, 04:16 PM
JEFFFAFA's Avatar
This one?
C8TA4602FJ...68/72...302,360..NPG & T18...131" WB...8 3/4" & 9" R.G....40 5/8" long.
  #499
Old 07-21-2014, 05:26 PM
HIO Silver's Avatar
Quote:
Originally Posted by JEFFFAFA View Post
This one?
Awesome. Thanks! That must be the one.. .YOU'RE THE BEST! I'd visit your parts department any day of the week.
Btw, I might be ordering another one of those late model spoilers for my 71 F250... this time the 8-inch deep version... Gotta get the hubcaps done first.
  #500
Old 07-21-2014, 05:30 PM
JEFFFAFA's Avatar
Nooo Proablem Mon. (In my best island accent) That's my gig.
  #501
Old 07-21-2014, 09:11 PM
HIO Silver's Avatar
Hmm... that doesn't even remotely sound Hawaiian.
  #502
Old 07-22-2014, 10:42 PM
HIO Silver's Avatar
Shadetree Electrolysis Vat
My 30-gallon setup can handle brake drums, rotors, and spindles but it can't handle a driveshaft. It's time to improvise!
Some old fence boards, masonry units, and scrap plastic sheeting and temporary vat is borne. Howz about that?! After a short bucket brigade from the setup, it holds about 10 gallons of solution. We've been having some very rare summer showers so the charger is under a little hut.
The driveshaft is slowly cooking away as indicated by the bubbles. The yoke came out great and is under a coat of primer already.
I just might have to build a good one to handle radius arms.
  #503
Old 07-24-2014, 12:35 AM
HIO Silver's Avatar
'Came home from work to find that the driveshaft was done cooking. Yay! Scraped off the remaining grit and black scale with a wire brush, Scotchbrite pad, and then washed off the residue with dishsoap and water. Dried it off, hung it from the painting tree, and gave it three coats (one dry and two wet) of etching primer. It'll get painted and U-joints installed this weekend. I found a free stencil font at 1001fonts.com that which closely matches the original stencil. It's called "Boston Traffic".
The temporary vat was disassembled and most of the solution returned to the permanent vat. EZ. The iron-rich solution is good for your plants.
  #504
Old 07-26-2014, 09:47 PM
HIO Silver's Avatar
Printed the PN, hand-cut a stencil, and re-shot the driveshaft PN.. no yellow spray paint on hand so an epoxy appliance white had to do. It's probably just as sloppy as the Milpitas workers did back in the day. The driveshaft is painted cast iron grey to break up the blackness of the suspension.
  #505
Old 07-26-2014, 10:11 PM
Gembone's Avatar
Gembone Gembone is offline
Gembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to beholdGembone is a splendid one to behold
looks nice. Keep it going. I can't wait for the maiden voyage video.
  #506
Old 08-03-2014, 11:39 PM
HIO Silver's Avatar
BAM! This is my 10,000th post. Onward!
Not much work on the LBB lately... I'm tired to seeing the yard tractor project in my yard and have been working on it so it can go back to its owner. It's really coming together. The "reveal" is a couple of weeks away!
  #507
Old 08-04-2014, 06:07 PM
JEFFFAFA's Avatar
Also this thread has gone over 500 replies. Congrats Hio.
  #508
Old 08-08-2014, 10:39 PM
HIO Silver's Avatar
Lo-Buck Tractor Project Update (from Post #350, Pg. 24)
'Finally got around to shooting the engine cover, foot plates, and a touch-up coat on one cowl cuz I wet-sanded through. Assembled it this evening.
It's Ace Hardware Signal Orange (Rustoleum) through a Harbor Freight HVLP. If there is any trick, it's to thin the paint by about 25 percent. This stuff dries soooo slooowly that the first coat is a light fog that sits for about 15 minutes to tack up, then 15 minutes between coats. .. that's in 80 to 85 temperature. Longer if you've got high humidity. Follow these steps and you'll be rewarded with no sags or runs!
'gotta finish up the electrical, build the cooler rack, and install the seat.
.. then it's back to the LBB. I did install new U-joints and reassemble the driveshaft.
  #509
Old 08-18-2014, 08:59 PM
HIO Silver's Avatar
Finished
'had to finish this project before getting back on the LBB. It has been parked in my yard and leers at me whenever I come or leave home.
It is DONE.
.. and it's gotta have a cup holder. It's from West Marine, a boating store, and has a gimbal so it shouldn't spill a drop when things get rough.
Onward to the LBB......
  #510
Old 08-18-2014, 09:28 PM
Binkowski's Avatar
Binkowski Binkowski is offline
Binkowski is starting off with a positive reputation.
mower?
Is there a mower deck on that? Or are you moving airplanes? Incredible work, so clean.
Oooops... I did it again. 71 F250 HIO Silver 1967 - 1972 F-100 & Larger F-Series Trucks 149 06-01-2016 10:14 AM
HIO Silver's '73 F100 SB 4x4 "The War Machine" Mod/Upgrade Thread HIO Silver 1973 - 1979 F-100 & Larger F-Series Trucks 152 05-02-2016 03:26 PM
Decision Time - Blackwall out or raised white letters out? HIO Silver 1967 - 1972 F-100 & Larger F-Series Trucks 36 08-27-2015 07:56 PM
Today's Honey Hole Find! HIO Silver 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-12-2015 12:13 AM
Today's Salvage Yard Score... HIO Silver 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-28-2013 11:17 PM
Tags
1970, 69, 73l, bar, budget, build, bumpside, f100, fordtrucks, hiosilver, idi, junk, retrofit, swap, sway, wrecking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
