HIO Silver's Lo-Buck Bumpside Build
#467
Thanks... soooo glad this project is making progress!
.. and we'll fix that visual anomaly with 70 series in front and 275/60s in back.
I opened the shocks and sealed hardware bags which came with the Fatman Fab kit... what's wrong with this pic? Yup.. it's friggin' missing an upper shock bushing .... musta been packaged on a Friday at 4:55 PM. :
#468
Here are my shop copy drawings for the leaf spring saddles and the shock adapter brackets. Fab your own C-notches using 4-inch DOM tubing and 3/16ths plate steel to box your frame....
65-69 Ford 100s use Monroe #34817 shocks (loop mounts on both ends). They are OEM spec'ed as front shocks for 63-87 Chevy PUs.
70-79 F100s use Monroe #34899 shock (stud top mount & loop at the bottom). They are OEM front shocks for 75-91 E100 Econolines).
Saddles... The taller saddle (4-inch side) is installed to the rear:
Keep up the excellent work, it's helped me out loads with research.
Rich, UK.
#469
Hello HIO, loving the work and fabrication, I'm hoping that work starts on my '72 next week if the lorry in my allocated space is removed. I'm also going for the rear axle flip to go with '94 Jag IFS. can you confirm the measurement on the short saddle please, it says 3"/16" ?? I'm also guessing that the different lengths with the 4" to the rear is to set the correct pinion angle?
Rich, UK.
Rich, UK.
#471
'Got the rear brakes, cables, and rear shocks mounted.. need to get a shock bushing on the next JY hunt. Also installed a replacement coupling shaft. .. The TKO's tailshaft is 23.25 inches from the centerline of the carrier bearing bracket mounting holes. A coupling shaft from a C6-equipped long bed, which has a 31-spline yoke, slid right on. Slightly more than half of the yoke slips into the TKO so it fits like a flesh tuxedo. I'll be able to reuse the stock driveshaft since it has slip-splines. The original is rusty and gunky as hell so I'll refinish it this week and then tuck it away... it'll be easier to work on the exhaust without it installed.
I'm gonna skip the gas tank swap for now. The rear crossmember needs to be relocated and accessing the rivets will be easier with the bed removed.
Back to work on the exhaust, EFI, and bodywork... the grill shell has been sitting in my living room for months!
#472
#475
#476
#477
#480
on
Yeah but we our only on this planet minute by minute per say and never know the leaving date.
So enjoy the toys as long as it don't affect the family and the roof over your there head:
I've had some friends that wait till they retired with everything paid for only too die with in a month after retiring.
If a guys is not married and never has to worry about the roof over head, then let your better judgment and check book be your guide..
Orich
Orich
