Chevrolet's desperation taken to hilarious new level.
Quote: "GM is famous for hosting things like this...Where they compare their trucks to Ford and/or Dodge with their truck always winning by a landslide in every scenario they test them in. Yet they somehow neglect to leave out crucial information such as gear ratio/curbweight/transmission type...etc...etc."
GM is owned by the government....did you expect a fair comparison?
There's a few other cars thrown into the mix but the Pinto and Chevette are there!
1977 Dodge Colt Hemi Comparison Ford Pinto Chevy Vega Chevette Datsun B210 Promo - YouTube
For those of you who don't live in the "snow belt", you should see how well those stiff a$$ hydroformed frames hold up with you hang 800 to 1000 lbs of snow plow off the front. Not to mention the extremely wimpy IFS front ends dragging on the ground when you pick the blade up. It's not uncommon to find stress cracks in the front section of the frame on the 88 and newer IFS GM trucks that are using snow plows. They are typically found right behind the rear most upper control arm mount. I have seen several situations where the frame rail broke right off in this area, and that was on 1/2, 3/4, and 1 ton models. As for the locking differential that GM uses, it's a joke too... it's the G80 code "Gov Loc". Also known as "Gov Bomb" These so called lockers in order to lock in require a difference in speed from one wheel to another in order to kick in. It's not uncommon to see these launch through the cover and splatter on the ground. All it takes to destroy a Gov Loc is getting stuck and mashing the gas a little too hard then BOOM! Pieces and parts everywhere! Tough trucks huh?
John
John
I came across a snow plow forum a while back on cracked frames with GM trucks with snow plows. Forgot what exactly got me there but I was reading for a while. Kinda funny guys talking about how they are welding up frames on their new trucks.
As for GMs "locker" I've seen vids of how it works and how much speed difference is needed and how jerky it is. I didn't know it was that weak. Honestly I wish Ford would just offer a Trutrac diff option on their trucks or at least a LS that is not next to worthless. I believe Fords "locker" only works at low speeds in 4wd which is kinda limited IMO.
thats no joke, i spent 6 month working at a place that did mostly snowplows and service bodies, you should see all the extra bracing that chevy's need, most specifically from the plow undercarriage back to the front crossmember. also, they are freakishly thin. dont even need to dig out the frame drill cause a harbor freight 1/2 air drill will cut through it like butter.
That's funny that you guys bring up plows because around here F-150's are the only 1/2 tons that have recommended mods to mount a plow and a couple companies make you sign waivers if their plow is intended for an F150.
Of course I'm guessing you all are referring to 3/4-1 tons. At the same time , though, we have a 1994 Suburban at work that has had a plow on it for 10+ years and we have never had an issue with it. It sit's with the plow mounted all through spring, fall and summer yet still no problems. The tranny lost reverse last year and you need a tetanus shot from just looking at the undercarriage but it still plugs along. Weird, huh.
on
all these ads favor themselves... would expect anything else?
The GMs that I was reading about were the later models primarily 3/4 and 1 ton trucks. The company I worked for has and still uses a 94' 2500 with a 350 auto. It has actually held up pretty good over the years and it still has the original engine and trans in it. Snow can vary from year to year in my area so some years it doesn't see all that much plow duty. I had to do some work on it with the plow and to add a salt spreader so I got to climb around under the truck. The frame was not impressive at all especially from the back of the cab back. My 74' F-100 has a more beefy frame in most areas compared to that thing. I'll give it to that 94', it has lasted but the ergonomics, fit, finish, refinement and etc was not up to par with what Ford had to offer in the same MY IMO.
#30
Even for my own driveway, if it doesn't have a straight axle up front I won't plow with it, PERIOD. I can't stand any of the newer GM trucks, heck they quit building trucks in 72! As for the Gov Loc, yeah it's a total pile of $#!t, I see enough of them come into work everyday blown to pieces. It doesn't take long to convince the vehicle owner to buy something else... typically they end up going with a Detroit True Trac, which is by far a much better unit. We have yet to have any complaints. I will say GM was smart to go with the Isuzu Duramax and Allison transmission, the rest of the truck just sucks.
