Vacuum Pump Story
Old 04-12-2012, 10:55 PM
Krazymaan's Avatar
Krazymaan
Krazymaan is offline
Vacuum Pump Story
Driving on the Freeway, sounded like the turbo sped up and whistled a few times. Then smoke comes roaring from under the hood and loud broken metal spinning noises. I get the van to my jobsite and take a look. The shaft for the Vacuum pump busted behind the bearing and created trouble for me. But my Ford Dealership had a new vacuum pump, vacuum pump pulley and serpentine belt. About 45 minutes later it was changed out by me and everything was back to normal. Had to buy a ford powersteering pulley installer but we always love new tools don't we.
Old 04-13-2012, 06:10 AM
Tugly's Avatar
Tugly
Tugly is offline
Vacuum pump? I can remember the water pump, power steering pump, HPOP, alternator, and the AC compressor. I am unfamiliar with a vacuum pump.
Old 04-13-2012, 06:35 AM
mongo75's Avatar
mongo75
mongo75 is offline
I'm not a van expert either, but the only vacuum pump I know if is an electrical pump on the passenger side. Please elaborate!!
Old 04-13-2012, 06:41 AM
landmobile's Avatar
landmobile
landmobile is offline
My 97 E350 has one, it supplies vacuum to accessories and the power brake booster. Mine went bad as I was backing into a parking space at the local convenience store. All of a sudden, no vacuum, no brake boost, hard pedal. I hit a steel pole at the end of the parking spot before realizing what was happening, and it cost me a vacuum pump and a rear bumper. The pulley is pressed on, as I recall, and I didn't feel like buying the special puller, so the stealership got me on that one.
Old 04-13-2012, 06:46 AM
Tugly's Avatar
Tugly
Tugly is offline
Ah... thank you.
Old 04-13-2012, 07:54 AM
Krazymaan's Avatar
Krazymaan
Hmm I thought all these diesels had a vacuum pump because they don't make vacuum because they are diesels. Its on the drives side has a black smooth face pulley about 4" in diameter and is held on with 3 - 10mm bolts. The black hose coming out of it goes directly to the brake booster. Take a lookske and see where your black hose from your brake booster goes to, maybe you will be surprised.
Old 04-13-2012, 08:23 AM
mongo75's Avatar
mongo75
mongo75 is offline
You're talking about the power steering pump. It also powers the hydro-boost power braking system. The only vacuum pump I've ever heard of is the one on a gas vehicle to suck fumes from the tank IIRC.
Old 04-13-2012, 08:42 AM
mueckster's Avatar
mueckster
mueckster is offline
The E series vans and OBS F series trucks, with diesel engines, are equipped with the belt driven mechanical vacuum pump.
Old 04-13-2012, 08:46 AM
landmobile's Avatar
landmobile
I'm not familliar with all years, but the 7.3 vans I have seen use the vacuum pump you're describing, while the F series use the PS pump for power brake boost. The pickups do have a vacuum pump, but it is a small electric unit mounted on the passenger side fender and it only runs the HVAC controls and front hubs (if equipped).
Chris
Old 04-13-2012, 09:34 AM
mongo75's Avatar
mongo75
mongo75 is offline
Thanks for the clarification Roland! I wonder why they didn't just stick with one or the other....
Old 04-13-2012, 10:10 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
The different firewall configuration in a van most likely doesn't leave room for the hydroboost and they had to use a vacuum boost. JMO
Old 04-13-2012, 11:43 AM
mongo75's Avatar
mongo75
mongo75 is offline
Gotcha! makes sense.
MTB17
25
02-08-2018 10:47 PM
wildstang
10-01-2010 12:16 PM
duck fan
26
11-20-2009 01:29 PM
masterc16
07-10-2006 12:29 AM
johnsdiesel
12-19-2004 01:31 PM
Quick Reply: Vacuum Pump Story
