rear drum replacement - Ford Truck Enthusiasts Forums
Old 04-12-2012, 10:26 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
This may sound like a dumb question, but how do you remove the drum on the rear of an 86 f250 4x4? I beat it pretty good and cracked it, now it's gotta come off. I'm battling the soft pedal, hardly any brakes syndrome and need to see if I need rear shoes or not. Any other truck with drums would come right off with a couple taps of a hammer
Old 04-12-2012, 10:45 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
It will depend on the axle, but you may need to remove the axles themselves and then a big nut & bearings inside of there.
Old 04-13-2012, 02:00 AM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
If the drums are worn enough to have created a ridge you might have to back off the shoes enough to get them off also.
Old 04-13-2012, 08:05 AM
BRay09's Avatar
Quote:
Its a full float rear end, but the drums look different than my 89 and 95.
I'm assuming it's the d70 rather than the sterling. What's the procedure to get those o axles out? Seems like a lot of Ford engineering to change some freaking brake shoes....
Old 04-13-2012, 11:49 AM
big vann big vann is offline
big vann is gaining momentum as a positive member of FTE.
Kedwinh is right,you'll have to back off on the brake adjuster to retract the shoes.The drum should then come off like any other.My 10.25 full float sterling was stubborn so I poppd out the rubber from the adjuster access slot,backed the shoes off and the drum slid off.I forget which way I had to turn it,but if it starts to expand the shoes just go back the other way.
Old 04-13-2012, 11:55 AM
81oneton400's Avatar
81oneton400 81oneton400 is offline
81oneton400 is starting off with a positive reputation.
Not sure if it will help you but I found it very Informative.
A Boy and his Jeep Dana 60/70 Rear Drums
Old 04-13-2012, 12:14 PM
EL_JEFE32's Avatar
EL_JEFE32 EL_JEFE32 is offline
EL_JEFE32 is starting off with a positive reputation.
You have to take axle cover bolts and cover off and then there is a rounded hex nut that has to be removed like ctubutis was saying. If you dont have the size sears sells them the cheapest i found and most parts stores want too much to order them. Depending on how its set up there may be the retaining bolt with another bolt to lock it in there or if it's one bolt they used either a star looking washer that needs to be bent back to let the nut spin or if it's like mine it has a plastic centered nut that little locking shims hook into. Trust me the little clips are hard to find anymore but when you take that off the axle slides out and you pull the bearings and check them as well. Once that's out back the brakes off through the adjustment hole in the inner side and pull the drum off.
It can be a pain to do the first time but once you get it once you'll never have a problem. I would recommend doing everything you want to in there while it's off so you don't have to do it several times. Also have your wheel high so she doesn't leak gear oil out while your in there. Good luck!
Old 04-13-2012, 12:17 PM
EL_JEFE32's Avatar
Good link forgot about that one. That explains it all there. You posted it while I was typing.
Old 04-13-2012, 04:53 PM
BRay09's Avatar
Ehh... I'll put the front pads on for now and see how they feel. It's just a mud truck, never sees the road. If it needs it I'll pull it apart. Thanks for all the help, I'll refer back to this if I ever need to do a brake job for someone
Old 04-13-2012, 05:29 PM
Well thats completely different from the full floating 10.25 sterling!I like the simplicity of the sterling but I hate having to readjust the brakes every few months.
Old 04-13-2012, 06:15 PM
ctubutis's Avatar
Quote:
Yup, sure is....
Full-floating Dana....
Thanks to 81oneton400 for posting that link. Pictures are way helpful sometimes.
Old 04-14-2012, 10:55 AM
Another inormative link for the favorites just in case I decide to do a diff swap.
Old 04-14-2012, 02:31 PM
BRay09's Avatar
I put the pads on and got it put all back together and it stops a little better than before. I don't think the rear are doing anything because this stock 351w will spin these big 39's with 4.10 gearseasily when power braked. Looks like ill be tearing into it
Old 04-14-2012, 03:23 PM
It doesn't look too difficult BRay 09.I think that if you follow the procedure in the LINK you'll be fine.
Old 04-14-2012, 06:25 PM
BRay09's Avatar
I didn't think it looked difficult, just time consuming and I wanted to get out and play ASAP. But I'll spend the extra cash and do it safely
Frozen rear drums - Tips/Help Tylus 1987 - 1996 F150 & Larger F-Series Trucks 26 02-03-2017 10:02 AM
Brake Drum Removal - D60 Rear Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-17-2015 05:52 PM
Pull Rear Break Drum? fridgeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-18-2013 11:14 AM
78 F250 4x4 rear brake drums Al D 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-07-2010 04:05 PM
How to get drum off 86 F250 3/4 Ton salewit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-12-2005 02:25 PM
Tags
1025, 1986, 1997, 46, 89, brakes, brand, drum, drums, f150, f250, ford, rear, removal, remove, replacement, sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
