79 300 to 93 300
Old 05-02-2012, 05:53 PM
Sabalon Glitz's Avatar
Sabalon Glitz
Sabalon Glitz is offline
79 300 to 93 300
First I want to say great site... lots of info! I've searched and think i'm correct in what i've found but want to make sure. I have a 79 F100 with a stock 300 that has finally died. I've got a 300 that came out of a 93 f150 that is fuel injected. Can I just take the fuel injected manifold off and replace it with my carb manifold and be back in business? Any help would be greatly appreciated.
Old 05-02-2012, 08:04 PM
f100jim's Avatar
f100jim
f100jim is offline
No problem on the swap. You can bolt the carb intake on and and swap distributors and go. The only significant differences between the engines is 1) The EFI engine has slightly higher compression and has the "fast burn" cylinder head chambers. Because of this, you will probably need to back off the ignition timing a little. and 2) The EFI engine does not have the hole for mounting the mechanical fuel pump, so you will need an electric fuel pump.
Old 05-03-2012, 07:59 PM
Sabalon Glitz
That's what i was wanting to hear. Now I can work on getting the ol' girl back on the road where she belongs. Thanks for the help
Sabalon Glitz
05-02-2012 06:32 PM
Jim's66
02-25-2012 07:36 PM
ndmccann
10-16-2011 10:50 AM
Econoline 150
03-04-2010 02:37 PM
trouble
03-29-2003 09:47 PM
Quick Reply: 79 300 to 93 300
