Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #16 (permalink)
Old 04-16-2012, 03:38 PM
Brad_81Ford Brad_81Ford is offline
Garage is empty, add now
Brad_81Ford is starting off with a positive reputation.
So, would using the original washers that were on the engine work with the studs and nuts? I still have the exhaust manifold 'log' I took off, as well as all the bolts. I assumed this was a stronger, safer bet. Does your set up work as you described by shaving some of the washer down or is it an on going issue?
  #17 (permalink)
Old 04-16-2012, 03:52 PM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer is gaining momentum as a positive member of FTE.F-250 restorer is gaining momentum as a positive member of FTE.
Use new studs with old washers shaved down, IF you are using a 4v intake with the Hedman headers. If the flanges are the same thickness, then any system will work.
I've been using the oem washers, shaved down, on my system for almost three years.
  #18 (permalink)
Old 04-16-2012, 08:30 PM
I will be using the Offenhauser DP intake with the EFI dual manifolds. Does the whole washer thang still apply?
  #19 (permalink)
Old 04-16-2012, 09:30 PM
Don't think so. We need Harte3 or AbandonedBronco to chime in here. You might want to PM them and ask if they don't put in their two cents. k
  #20 (permalink)
Old 04-17-2012, 09:14 AM
Amphenol Amphenol is offline
1983 Ford F-100
Amphenol is starting off with a positive reputation.
No need to grind the washers if your using the efi manifolds. BTW, I ordered my studs and crimp nuts from truckmeblue.com. But, any do it center will have them.
  #21 (permalink)
Old 04-17-2012, 09:16 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco has a good reputation on FTE.AbandonedBronco has a good reputation on FTE.
I haven't had an issue with the Offy and EFI manifolds. They seem to be the same thickness.
Click the image to open in full size.
Click on this link for the full sized picture. You can see the detail quite a bit better:
1981 Ford Bronco Manifolds | SuperMotors.net
__________________
1981 Ford Bronco. 300I6 Offenhauser DP Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.00 rear 9" EFI Manifolds. 2.5" high flow cat/muffler.
1984 Ford Bronco. 300I6 Offenhauser C Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.55 rear 8.8" EFI Manifolds. 2.5" high flow cat/muffler.
Supermotors Pics
  #22 (permalink)
Old 04-19-2012, 01:13 PM
Wagonboy's Avatar
Wagonboy Wagonboy is offline
Wagonboy is starting off with a positive reputation.
The dorman studs i have found say they are grade 8.
Dorman Products - 675-101.1
Someone else please verify this size for me, please?
buck .49 at autozone => http://www.autozone.com/autozone/acc...er=894808_0_0_
  #23 (permalink)
Old 04-19-2012, 06:06 PM
gudor gudor is offline
gudor is starting off with a positive reputation.
Google: Hillco Fastener Warehouse,inc. I think you can buy online and have shipped.
Tel: 714 657-7442
You need 14 of each of these: AV09686 3/8-1 SAE 3/8-5/8 USS X 2 overall *(I like to use the 2 1/8" studs if they have them.
9SAE500HD 1/2 SAE Heavy Duty Flat Washer
8SAE310 5/16 SAE Flat Washer Grade 8 Yellow Zinc
838024GC 3/8-24 Grade C Locknut
Coat the coarse threads with anti sieze compound. Get two 3/8 X 24 nuts, screw them on the fine thread end and torque a bit against each other. Then insert into head and tighten with open end wrench 20 lbs torque, approx. Put an open end wrench on each nut, and remove nuts. Repeat 14 x.
Use Mr. Gasket #260 int/exh gasket.
Thank you F-250...
For those of us struggling to find them on their site, you need to call the company (currently these studs are not located on the website)...so you have to order over the phone
- 714 657-7442
Also, you might ask about pricing for the bolts. I got the 2 1/8" (#
AV09688). They were $2.26 each, or less than $10.00 for a pack of 10. So I just went with two packs of 10 (four of them would be about the same price as 10).
  #24 (permalink)
Old 05-03-2012, 05:55 PM
kas83 kas83 is offline
kas83 is starting off with a positive reputation.
Do these studs work on an EFI engine? I'm getting everything together to install my reman'd head on my 92, would be awesome if I could use these instead of dinking around with the bolts. Thanks in advance.
__________________
2000 F250 CC/LB 4x4 V10 Auto, completely stock, but that will be changing come tax time
1992 F150 SC/LB 4x4 4.9 I6 5 spd, completely stock and less miles than my SD
  #25 (permalink)
Old 05-06-2012, 08:31 PM
Anything? I do know there are some differences between EFI n carb heads/engines, just making sure it can be used.
  #26 (permalink)
Old 05-07-2012, 08:58 AM
1981 Ford Bronco
Hey Kas83,
I can't think of any reason why it wouldn't work. The bolt pattern and heads are externally nearly identical.
__________________
Supermotors Pics
  #27 (permalink)
Old 08-29-2012, 11:14 AM
john165 john165 is offline
john165 is starting off with a positive reputation.
Quote:
Originally Posted by Wagonboy View Post
Will these Studs from Autozone work? I am pretty sure the thread size is 3/8-16 on the old bolts. All my bookmarks and such have been deleted and so I was wanting to make sure if these would work. The price is good and my Local Autozone is minutes away.
The info say they are grade 8, resistant to rust while being 2 inches long.
__________________
1984 F250 4.9 4x4 4Speed
1984 F250 4.9 2/4 4Speed
1995 F150 5.8 4x4 Auto
Tags
200, 300, 49, carb, dorman, efi, enthusiast, f250, ford, forum, inline, restorer, studs, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
