Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-12-2012, 08:23 AM
mkrog mkrog is offline
Garage is empty, add now
mkrog is starting off with a positive reputation.
Question Rear sump pan dip stick.
I put a rear sump pan on my 351C and I was looking at the dip stick and it looked strange to me.The dip stick it self only sticks out of the tube about a inch,is that right?It is the right dip stick,Ford part #D7TE-6750-BA.The add and safe marks are up in the tube,how does it read the oil level?.
I read that it takes 6 qt. of oil with the rear sump,is that with a filter?
  #2 (permalink)
Old 04-12-2012, 10:56 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.mark a. has a very good reputation on FTE.
The rear sump dipstick tube is probably about 2 feet long and has a mounting tab that bolts to one of the exhaust ports monifold bolts.
The pan holds 6 qts and 1/2 qt for the filter but there is nothing wrong with just running 7 qts in it. With 7 qts the level in the pan isn't close enough to the cranks rod throws to make any difference.
__________________
'79 F250 13" lift 42" Super Swampers
Tags
1978, 351, 460, 69, add, diesel, difference, dipstick, dipsticks, ford, idi, installation, length, marks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
