Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-11-2012, 08:26 PM
Hostilact89's Avatar
Hostilact89 Hostilact89 is offline
2003 Ford F-250
Hostilact89 is starting off with a positive reputation.
Lag shifting into drive f250 5.4
I seem to be lagging on the shift going from park-drive, rev-drive, neutral-drive. there will be a 2-3sec delay then a slight jerk forward nothing like hard jerk just the truck moves forward without tire movment...... Any ideas?
  #2 (permalink)
Old 04-12-2012, 06:21 AM
projectSHO89 projectSHO89 is offline
Garage is empty, add now
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Check the transmission fluid level.
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #3 (permalink)
Old 04-12-2012, 07:26 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Could be low.
__________________
Speed is a question of money. How fast "CAN" you go?
  #4 (permalink)
Old 04-12-2012, 11:42 AM
2003 Ford F-250
All fuilds were changed and topped off last week. just double checked and trans fuild is full
  #5 (permalink)
Old 04-12-2012, 04:49 PM
Provide more details.
How long has it been happening?
Was it the same before as after the fluid service?
What fluid was used?
Was the transmission filter also changed?
Was the fluid level checked in accordance with the manual?
Are there ANY other transmission-related anomalies?
How many miles on transmission?
Any prior service history on the transmission?
Recent service on the vehicle?
Which transmission?
__________________
  #6 (permalink)
Old 04-12-2012, 08:49 PM
2003 Ford F-250
-It started about 3 months ago, I thought it was the fluid so i had it changed.
-It is the same as before i changed the fluid
-Not sure what fluid was used, the shop that did repairs on my truck did it when i brought it in for a follow up
-I dont think the filter was changed with the fluid
-Yes it was done by the book
-No other trans issues that i have noticed
-It is the original trans truck has 101,800 miles on it
-No prior service history on it other than the routine check ups
-Recent service, Cleaned the air filter, oil change, oil filter change, all fuilds topped off.
-Not sure which trans it has, as far as I know it is the stock one that came with the modle. 2003 F250 5.4L Fx4 XLT Tow Package
Sorry I dont have all the information you mentioned, a little new to this whole trouble shooting thing.....on ground vehicles at least
  #7 (permalink)
Old 04-12-2012, 09:32 PM
Once it does engage, are there any other transmission or driveability concerns during normal driving?
Any delay when shifting into reverse?
Directly to either first or 2nd?
__________________
  #8 (permalink)
Old 04-12-2012, 11:40 PM
2003 Ford F-250
No other delays that I can tell, if so they are so minor that I cant notice them. It only seems to be going from rev/neutral/park into drive. 1st-drive is fine, and 2nd-drive is fine.
  #9 (permalink)
Old 04-13-2012, 07:27 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
How about neutral-2 and neutral-1?
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #10 (permalink)
Old 04-13-2012, 07:29 AM
It *might* any of several things including a restricted or leaky filter, a weak pump, valve body components sticking or leaking, or an internal clutch or accumulator problem.
I've sent a message to someone with far more expertise that I have to take a look at your symptoms. Hopefully, Mark will be along in due time and will be able to comment with more depth. Having a transmission thread in an engine forum isn't a good way to attract the right expertise.
edit: Speaking of...
__________________
  #11 (permalink)
Old 04-13-2012, 12:46 PM
2003 Ford F-250
Well i just checked and It seems to be fine neutral-2 but neutral-1 it does do it.
Tags
2003, 250, 350, 54, chevy, delay, delays, diesel, drive, ford, lag, park, ranger, shift, shifting, suppose, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
