6.7 Wind Noise and Door Rattle remedy - Ford Truck Enthusiasts Forums
Old 04-11-2012, 07:57 PM
tolliewolly's Avatar
tolliewolly tolliewolly is offline
tolliewolly is gaining momentum as a positive member of FTE.tolliewolly is gaining momentum as a positive member of FTE.
Hey everyone.
I know we have been talking about this some on the forum and after alot of research I wanted to post my results and findings. I hope this helps everyone.
My superduty had rattles on the doors. It sounded like it was coming from the plastic inside part. I have battled thses for months and have finally found what it was.
Come to find out is was the glue adhesive that Ford uses to put the moisture barrier in. The simple way to fix it was to duct tape all of the edges up behind the door skin. Tape up the moisture barrier at the edges and put the skin back on. I added some foam behind mine to firm up the plastic skin as well. It was tough getting the skin back on but sure did help it alot. I did this to both front doors. Was not necessary to the rear ones.
With the wind noise beside the head on the drivers side.......At first I thought it was the window seal but that was not it come to find out. I looked a tthe passenger side and looked at the drivers wondering what it could be. I noticed that the drivers door at the top was not in line and laying flat with the rear door. From the plant......Ford had the door at the latch side too high. It was only off maybe 3 16th's......very small but I lowered the door with the striker. Got the door in line with the back door from top to bottom. I also did Epics door mod with the surgical tubing.
I lined up the door and tested it a few times. Made minor adjustments and wah lah!!!! Solved. Im pretty sure I got 90% out of it. I can still hear A LITTLE but it may be my imagination. Its probably in my head at this point since I have been ticked at the truck since I bought it. My dealer wont help so it has been very frustrating.
These are the tips to solve those problems. If you need any help or questions them pm me and I will be more than happy to help.
I hope mine stays quiet. That wind noise thing has come and gone before so I will post in a few months on how shes doing. As for now I tightened everything down and am gonna let my 6.7 haul!!!
Old 04-11-2012, 09:41 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Good news then !
Looking at the continuous weatherstripping they have on my 12 cc lariat, I am stunned the wind noise is so bad !
Now I do run around without radio a lot cuz I like the quiet and hearing the engine, but man, I got's to do something about it myself....
Soon as I get the 5'er ready for our trip on the 25th, will redirect my attention to the wind noise !
Old 04-12-2012, 01:27 AM
Shelby-GT-500 Shelby-GT-500 is offline
Shelby-GT-500 is gaining momentum as a positive member of FTE.
My truck is also a little noisy. I am going to start with Epics door seal mod. I really appreciate all of his videos!
Old 04-12-2012, 11:11 AM
Brandon Bloomquist Brandon Bloomquist is offline
Brandon Bloomquist is starting off with a positive reputation.
Tollie - Can you post pictures of the parts you adjusted to get the door in line? My imagination needs more coffee right now and I can't visualize this one.
Old 04-12-2012, 11:25 AM
Sailor_Roy's Avatar
Sailor_Roy Sailor_Roy is offline
Montana Chapter LDR
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
What is an Epics Door Seal Mod ??
Old 04-12-2012, 11:30 AM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Old 04-12-2012, 11:38 AM
Sailor_Roy's Avatar
Montana Chapter LDR
Thanks Savage
Old 04-12-2012, 11:40 AM
SavageNFS's Avatar
not a WHITE truck
Thank EpicCowLick...
(but thank you)
Old 04-12-2012, 01:14 PM
Quote:
No problem.....I kinda figured there would be some requests for some pics. I will take some tonight.
Old 08-13-2014, 04:27 PM
EFF250's Avatar
EFF250 EFF250 is offline
EFF250 is starting off with a positive reputation.
I had a rattle in my door that drove me nuts (2012 F-150). I localized it to the window switch panel. The switch mechanism is in a frame , which is in a frame and they're all loose. I just pryed out the panel and stuffed some small pieces of foam in the loose frames. Connected it back up, popped it back in and rattle was gone. As always....YMMV. Cheers.
WIND ROAR ROADHOGE250 1968-2013 Full Size Vans 3 10-19-2016 08:26 AM
HOW TO: Replacing Power Window Motors SVTDriver97 '80-'86 HOWTO's 4 06-23-2016 08:18 PM
Rear Door Skins mini_blaine 1999 - 2003 7.3L Power Stroke Diesel 7 10-25-2012 11:11 AM
2011 Superduty Wind noise and door rattles tolliewolly 1999 to 2016 Super Duty 0 04-11-2012 07:56 PM
1996 drivers side quarter panel removal mikeg216 1987 - 1996 F150 & Larger F-Series Trucks 5 11-22-2011 07:56 AM
Tags
150, 2011, 2012, door, duty, f150, f250, f350, ford, noise, rattle, rattles, super, taurus, wind, xharnass
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
