Dual Exhaust - Ford Truck Enthusiasts Forums
Dual Exhaust
Old 04-11-2012, 05:15 PM
mtntop1's Avatar
mtntop1 mtntop1 is offline
mtntop1 is starting off with a positive reputation.
Dual Exhaust
I have a 95 F150 with a 5.0L engine single exhaust and one oxygen sensor on the right side.If I change over to dual exhaust How would I add an extra sensor to the the other side
Old 04-12-2012, 12:52 AM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Quote:
Why would you want to add an extra one? I'd just put one back in it and call it a day.
Old 04-12-2012, 07:01 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Put the o2 in an H or X pipe or just on one side..
Old 04-12-2012, 09:52 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You don't need another O2 sensor for duals, just put one back into the head pipe near the passenger side collector or better yet into the passenger side header that you're also going to install(hint hint.. nudge nudge).
Old 04-12-2012, 11:56 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I'm going to switch to true dual exhaust soon in preparation for my motor swap. I'm going to leave the O2 in the stock location and run the pipes down the passenger side with a pair of Dynomax mufflers mounted on their side next to each other.
Old 01-07-2014, 09:34 PM
Mrschulz's Avatar
Mrschulz Mrschulz is offline
Mrschulz is starting off with a positive reputation.
I put long tube Hedman headers on my 93 302. Ran a crossover pipe at the first part of the straight pipe with a weld in bung for the sensor. Doing it that way catches both sides if the motor like it did stock at the Y pipe.
Old 01-07-2014, 11:36 PM
BbFord92 BbFord92 is offline
BbFord92 is starting off with a positive reputation.
Quote:
That's too far back to get a proper reading.
Old 01-08-2014, 12:09 AM
Mrschulz's Avatar
Quote:
True and I've thought about moving it back. I put two of those 18 inch pipes on there if I ever decided to move it back i could just throw them out and reweld. I just wasn't to keen of drilling into the new headers.
Old 01-08-2014, 12:12 AM
Completely understandable. Right in those new headers is the best place for them though, unfortunately.
Old 01-08-2014, 12:19 AM
Mrschulz's Avatar
I guess I can always fill with weld on the outside say I drill a little to big.
dual exhaust and dual inlet/outlet muffler edreckers Performance & General Engine Building 3 08-11-2015 05:13 AM
390 Exhaust question bignewf 1973 - 1979 F-100 & Larger F-Series Trucks 21 08-06-2015 03:53 PM
1946 Dual Exhaust? burnibunch 1947 and Older Ford Trucks 3 10-14-2010 04:39 PM
98' F150 Lariat Super Cab - Dual Exhaust compwat 1997 - 2003 F150 1 07-27-2010 07:03 PM
65 dual exhaust William 1961 - 1966 F-100 & Larger F-Series Trucks 9 05-30-2002 12:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
