Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-11-2012, 02:56 PM
hardtrucker8629 hardtrucker8629 is offline
Garage is empty, add now
hardtrucker8629 is starting off with a positive reputation.
Steering box to frame problem
Hello, I'm new to this forum but not to Ford's. The one that I am currently working on is a 1986 F-150 XLT Lariat. It has a 5.0 that is fuel injected with an auto. My question is this:
The other day it started wandering really bad, so I went over the front end and couldn't find anything. I re-packed the bearings and they looked in good condition. I just replaced all the tie rods and upper and lower ball joints as well as axle shaft joints less than a 1000 miles ago.
Went for a ride in it today and it is way worse. It was steering like it had a broken ball joint and I was really fighting the wheel. So, I laid under it and figured I had to find something. Lo and behold what i found was that where the steering box mounts on the frame. The frame is broke. This part of the frame is actually a section that is riveted to the main frame. I figured that would be an easy enough fix, just get a new "frame tower" from Ford and bolt it in...WRONG. It seems that Ford doesnt list any kind of part number for this riveted section of the frame. My question to you guys is this... Have you ever heard of this frame failure? and if so is there a company somewhere that i can get an aftermarket part to bolt on this area? I have done this with the shock towers, and the rear shackle mounts. Please help...
  #2 (permalink)
Old 04-11-2012, 03:09 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
Welcome to FTE.
Pictures would be cool.
Not to rain on your parade, but I'm not familiar with any sort of sections riveted to the main frame, I suspect you're looking at something invented by a PO.
These kinds of things can happen when people abuse the things - install oversize tires and/or go jumping around offroad.
Again, pictures.........
__________________
About the bra
  #3 (permalink)
Old 04-11-2012, 03:24 PM
Quote:
Originally Posted by ctubutis View Post
Welcome to FTE.
I dont have any pics at the present time. But it is a factory set-up, I have owned this pickup for the last 5 yrs, and know the original owner personally. Matter of fact I have changed the oil in this truck everytime since it rolled off the show room floor since feb. 1986. Its one of the reasons that i bought it from him. That and the fact that it only has 72K on it.
  #4 (permalink)
Old 04-11-2012, 03:30 PM
Archion's Avatar
Archion Archion is offline
Trained Parts Monkey
1996 Fleetwood Wilderness
My Garage
Archion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud of
Archion.Uberpimp PartsGuyMatt mvose OVC Archion
Are you talking about the cross-member that goes across under the radiator between the front frame horns?
__________________
Matt - Ninja Edit Master
02 Excursion XLT V10 4WD - 12 Escape L4 XLT AWD - 99 Mustang 3.8L 'Vert - 96 Wilderness 22LW TT
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
Carlisle - 2012 Mid-Atlantic Meet - Pic Thread >>CLICK ME<<
  #5 (permalink)
Old 04-11-2012, 03:34 PM
ctubutis's Avatar
Here is what the parts catalog shows for the frame:
__________________
About the bra
  #6 (permalink)
Old 04-11-2012, 03:41 PM
Quote:
No, this piece runs with the main frame along the inside of the driver's side. Its the part that is directly behind the steering box. The box gets bolted to it. It goes from just infront of the main crossmember that holds the motor mounts to just infront of the steering box itself.
  #7 (permalink)
Old 04-11-2012, 03:46 PM
if you look at that pic, on the pass. side just in front of the main cross member. thats just like the gusset piece that is on the driver's side. thats the part thast i need, or some sort of kit that i can weld in to strenghten the broken part.
  #8 (permalink)
Old 04-11-2012, 03:48 PM
ctubutis's Avatar
This is 2WD, correct?
Single shocks?
__________________
About the bra
  #9 (permalink)
Old 04-11-2012, 03:55 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
2003 Ford Ranger
My Garage
Fordzilla80 has a very good reputation on FTE.Fordzilla80 has a very good reputation on FTE.Fordzilla80 has a very good reputation on FTE.Fordzilla80 has a very good reputation on FTE.
I know what you're talking about. Did it just crack, or did it completely come out? The 70's trucks had a problem with cracking behind the steering box, and I have heard of it before on the 80-86 trucks, although not quite as frequently.
As far as a kit, I haven't heard of one. You're probably gonna have to find a way to either weld the crack, or remove that entire section from a donor truck, and then transplant it into your truck.
__________________
Shaun
-1980 Ford F150 4x4 Ranger Lariat
-6.6 400 V8/C6/NP208/D44/Ford 9.
-2003 Ford Ranger Edge+
-3.0 V6/5R55E/Ford 8.8
  #10 (permalink)
Old 04-11-2012, 04:03 PM
Single shocks?
No, its an F-150 4wd. And it had single shocks, but i swapped out the frame mounts and put the quad shock front end set up on it.
  #11 (permalink)
Old 04-11-2012, 04:32 PM
ctubutis's Avatar
I just looked through the same almost-100-pages of the steering/suspension/axle/frame sections of the same same parts book your Ford dealer did, I can't find such a thing, either.
If you know how to weld, you could probably fab up some sort of replacement reinforcing brace to replace that component with.
Or, take it to a frame & alignment shop, they could probably take care of it.
If you can get the old one out, and it's a separate, replaceable part, it will have a Ford Engineering ID number stamped on it someplace. Give us that number and maybe we can find it.
If no such number exists, the part is included as a component of some other assembly.
__________________
About the bra
  #12 (permalink)
Old 04-11-2012, 05:08 PM
kedwinh's Avatar
kedwinh kedwinh is offline
1985 Ford F-150
kedwinh is gaining momentum as a positive member of FTE.
Yep, a 1/4" plate welled over the area, after the cracks are welded up, should work fine. If your going to be running larger tires, you might want to check out the steering box brace like they use on Jeeps. It's a brace that bolts to the steering box and runs across to the right side frame rail.
  #13 (permalink)
Old 04-11-2012, 05:12 PM
ctubutis's Avatar
I just found a bit more.....
E6TZ-5K130-A REPAIR KIT (FRAME) Designed for 1986/88 F150/350
Contains a liner, 2 spacers, and a bunch of nuts & bolts & washers & instructions
But I have no information other than that.
Green Sales Company has 5 of them, might give them a call (800-543-495) to get some more specifics as to what, exactly, it's for.
A place called USD Inc. in Phoenix has 1 - 602-774-4809
EDIT: Googling that part number finds more information on it....
__________________
About the bra
  #14 (permalink)
Old 04-11-2012, 07:23 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
This does happen now and again on here, and oversize tires seem to aggravate the problem. You will probably need to hunt around your area for a good welder/fabricator who is confident enough in his work to take on the liability of the job.
__________________
Dave F
1989 F250 XLT Diesel
  #15 (permalink)
Old 04-11-2012, 07:55 PM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
1986 Ford F-150
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
Hey Chris, I think this is what's being discussed.
Click the image to open in full size.
I hope that helps.
__________________
Ron
1986 F150 4x2 SWB, down for restoration.
408 Stroker, Edelbrock top end, FAST EZ EFI, DJM Dream Beams, 4-link coilover rear suspension, Ford 8.8 diff, 3.55 gears, Eaton posi....
A work in progress. http://www.ford-trucks.com/forums/11...-el-guapo.html
Tags
1994, 2011, box, brace, cracked, dimensions, e6tz5k130a, f150, f250, ford, frame, identification, kit, repair, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
