Ok, I removed the 2 nuts off the back of my grill emblem on my 08 Expy..... Now can you tell me why it will not come off? I had a screwdriver behind it but it seems like it is glued on. Any help?
Yes the nuts were behind it and metal. It must be on there with sticky tape as well cause it will not come off. I will try the fishing line trik this weekend to see if it is sticky tape.
Mine had delaminated, so I decided to paint it, I also had to pry it to get it off and in the process broke of the two plastic pins that the speed nuts connect to.
I painted and reinstalled using a small amount of auto motive adhesive.
