2002 F-150 ac problem - Ford Truck Enthusiasts Forums
Old 04-11-2012, 02:07 PM
Jterr Jterr is offline
Jterr is starting off with a positive reputation.
How do I get the ac control switch out of the dash? Something must have come loose as I only get cold air or heat to the windshield...
Old 04-11-2012, 05:08 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You might want to check the FAQs in the HVAC section first....
Old 04-12-2012, 09:47 AM
Quote:
Where might that be? I can't find a HVAC section...
Thanks
Old 04-12-2012, 04:35 PM
HVAC= Heating, Ventilation, & Air Conditioning. Any forum sections have titles that look like that?
Old 04-12-2012, 05:55 PM
RebColonel RebColonel is offline
RebColonel is starting off with a positive reputation.
I don't remember what the dash looks like in a 2002 model if it's anything like my 1999
the radio surround just pops off and the heater/ac panel is held in by screws.
Old 04-12-2012, 07:48 PM
Got it , must be something else as all looks ok; as much as I can see. Need to check someplace else
Thanks
Old 04-13-2012, 12:03 PM
Possible loss of vacuum to dash or blend air door. The blend air door is notorious about breaking on these models. If it is the blend air door you will have 2 choices. Either remove the dash to replace it or use a Heater Treater repair kit. I personaly would use the kit.
Look on You Tube for the video on how to. You can order them online.
Old 04-13-2012, 01:50 PM
I don't have a blend door problem; as I get hot and cold air. It is the changing from, say defrost to blowing out the dash vents. Nothing happens when I change the settings just keeps blowing out the defrost vents.
Thanks
Old 04-13-2012, 09:49 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Check the vacuum supply line.
Old 08-22-2012, 08:39 AM
AngelasFord AngelasFord is offline
AngelasFord is starting off with a positive reputation.
Quote:
Thanks
I have the same problem,, I have checked the valves,, one was crimped as it had melted,,, still no luck. As I was driving yesterday I would hit bump, and it would switch to the dash, hit another bump back to the vents, then no cool air,, now its stuck in the dash
Old 08-22-2012, 08:43 AM
ac acting up again... help!
I have a 2002 f-150,,, I hate this truck, but I cant afford to replace it, so have to keep it running.
Yesterday while driving home, I would hit a bump and the ac would switchto the dash,, no cool air,,, hit another bump, switch to the vents,,, little cool air,, hit a bump and then back. Now its stuck in the vents with no cool air. I checked the vacume lines,,, had probs here before,,, fixed them,,, still nothing,,, stuck onthe dash....
please help, before I take it to a mechanic. I would love to fix and sell the thing,,,
Old 08-22-2012, 09:58 AM
I finally found the problem. It was a small vacuum line in the engine compartment. Fixed doing fine.
Thanks all
Old 08-22-2012, 10:09 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
'When function door is in defrost position, air inlet door vacuum control motor is at no vacuum, admitting only outside air into passenger compartment. Panel/floor door and panel/defrost vacuum control motors are at no vacuum, directing air airflow to defrost duct and side window demisters. Temperature can be adjusted to heat or cool air below outside temperature. A/C compressor will operate if outside temperature is above approximately 43*F (6*C). Blower motors is On.'
You're either not getting a vacuum source to the Panel/Defrost Vacuum Actuator or the actuator's diaphragm has a hole in it.
Old 08-22-2012, 10:11 AM
LOL, just before I typed this.
Hissing noise under hood, Bad AC compressor?? HELP! Robby Nash 1999 to 2016 Super Duty 0 12-18-2012 01:33 PM
AC no power ggirten 1999 - 2003 7.3L Power Stroke Diesel 5 10-12-2011 05:13 PM
AC wiring diagram 78sharpshooter 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-09-2007 08:50 PM
AC fine Max AC blows hot freerange Ranger & B-Series 13 07-18-2005 09:05 PM
Expedition Rear AC not working chaneyb Cooling, Heating, Ventilation & A/C 1 06-21-2005 03:42 PM
Tags
08, 2002, 97, ac, air, chip, conditioner, door, f150, f150ac, ford, hvac, problem, problems, truck, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
