F250 5.4L battery light comes on and off - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-11-2012, 09:56 AM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
I just typed a book and accidently went back a page and lost everything i had wrote... so i will start over
On my 03 F250 5.4L, i noticed on the way home from school yesterday my battery light was on so i checked my scangauge2, reported 11.6-11.7 volts. Got home, took my alternator out and brought it to napa where it failed their test. Bought a new $240 alternator from napa, put it in the truck and started it up and good to go. no battery light, 14.4 volts. drove 20 minutes to dinner and it was fine, drove 2 minutes and it was fine, then when i got in my truck to go home the battery light came on and i was down at 13.9-14volts. This morning headed to school, i was back at 14.3-14.4 volts and no light but just as i was pulling into the parking lot my battery light came on and dropped to 13.9-14 volts.
At this point im confused as to why the light keeps coming on and off and why the voltage only drops a little. Could it be from the napa alternator? Should i get it tested? ive been told these engines are picky and only like motorcraft alternators or weird things can happen like i am seeing. When i get home today im going to get a multimeter on the alternator and see what its putting out, and also check all the battery and alternator and ground connections. Does it sound like im on the right track here? Again, just confused as to why it turns on and off. Ill report back in a few hours to see if the light comes on when i go home from school. Thanks for any replies in advance
Old 04-11-2012, 10:41 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Is the light coming on at idle or when the engine is at speed?
Old 04-11-2012, 10:56 AM
acf6's Avatar
It comes on all the time. my dad thinks i should just bring it to the dealer but id rather just buy an motorcraft alternator and replace it myself in 5 minutes instead of wasting my time/money there...
Old 04-11-2012, 11:29 AM
redford's Avatar
Sounds like another bad alternator.
Old 04-11-2012, 11:32 AM
acf6's Avatar
I don't think napa will take the old one back in return...will they?
Old 04-11-2012, 01:04 PM
redford's Avatar
NAPA has warranties on parts. Go talk with them and let them know what is going on.
Old 04-11-2012, 01:22 PM
acf6's Avatar
Alright good. My dad is stopping at the ford dealer on his way home and picking me up a motorcraft alt and is going to bring the napa one back tomorrow and talk to them because he has an account there for work.
This morning at school i wiggled that connector wire a little and on my 7 mile drive home, volts ranged from 13.9-14.4 and the battery little came on and off 8 times. usually stayed on for about 10 seconds
Old 04-11-2012, 07:30 PM
acf6's Avatar
Replaced with Motorcraft alternator... so far so good
Tale of a battery light coming on.... klinquist 1968-2013 Full Size Vans 6 05-29-2015 01:31 AM
Proper alternator readings what should they be ? radmacks Excursion - King of SUVs 25 08-29-2014 07:31 PM
Alternator help "light circuit failure" garydmundy 1999 - 2003 7.3L Power Stroke Diesel 5 11-25-2013 09:45 AM
2003 7.3.....Alternator problems rwtdct 1999 - 2003 7.3L Power Stroke Diesel 14 08-07-2012 08:05 PM
Battery Warning Light? Nullsurfer 1999 - 2003 7.3L Power Stroke Diesel 3 11-04-2004 07:33 PM
Tags
1999, 2002, 2003, 2008, 54, 54l, battery, diesel, engine, f250, ford, indicator, light, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
