Propane? - Ford Truck Enthusiasts Forums
Propane?
Old 04-30-2003, 04:04 PM
theologian's Avatar
theologian theologian is offline
theologian has a good reputation on FTE.theologian has a good reputation on FTE.theologian has a good reputation on FTE.
Question Propane?
The next in the saga of my truck seems to be going in the direction of propane. I know nothing about this concept, so I need information as to why I should go this route, or indeed why I should not.
I have to contact Bell Transmissions in Bismark to find out if the transmission will manage an increase in power- they built the tranny so should know what it can take.
I have started looking at systems in other folks trucks, and it seems like a do-able thing. So guys, bring on the advice here.
Theo
Old 04-30-2003, 07:14 PM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
Propane?
I've been giving propane some thought, too, and have been doing my homework so I can make an informed decision. I asked Dale Isley, the developer of the TYMAR to send me some information, and as usual, he gave me plenty. It's too long to post here, but is very informative. If anyone is interested in having that info forwarded, email me at Quadzilla95(No Email Addresses In Posts!). I'll be glad to forward it to you.
Old 04-30-2003, 07:22 PM
theologian's Avatar
Propane?
Quadzilla, you got incoming.
Old 04-30-2003, 11:14 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Propane?
As a general rule: the more HP you make on #2, the less HP you get from propane.
As an example. A stone stock truck can get as much as 100HP from a propane system. The same system installed on a truck with a big chip, injectors, etc. may see as little as a 30HP improvement.
You dyno'd at 380 (if I am remembering the right post), to me that means a highly modified engine with big injectors, turbo, maybe even some cam work. Without knowing your setup I'd say propane might not be the right thing for you if you're looking for a big power boost, NOS may be the answer you seek.
If better milage accompanied by a smaller power gain is your objective, then a low flow system triggered at low boost would be perfect.
timing on propane engine joey2fords Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-14-2014 01:06 AM
EBPV... Now we're cookin' Tugly 1999 - 2003 7.3L Power Stroke Diesel 96 02-10-2014 01:16 PM
Assistance needed in Bismark fellro86 North Dakota Chapter 3 01-08-2013 10:30 PM
Propane Curious FordTrucksKickGM Alternative Fuels, Hybrids & Mileage 6 09-06-2007 10:21 PM
48 F-3 Springs jboren 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-26-2005 01:06 AM
Tags
d380, diesel, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
