Freaking Out - 53/56 F100 - Ford Truck Enthusiasts Forums
Old 04-11-2012, 12:14 AM
DasHaas DasHaas is offline
DasHaas is starting off with a positive reputation.
Hi I recently bought a 56 F100 long bed with a 53 cab so to the naked eye the truck is a 53. I have a title from another state (NJ) for a 1956 f100. I spoke to the original owner (google is great for looking people up) and he explained that the 56 cab was completely rotted out so he swapped it out for a 53 cab. There lies my problem, there is no VIN plate on the cab so I am hoping there is one stamped somewhere on the frame that I can uses as evidence that the truck matches the title and I can get it registered in FL. I'm VERY worried that I may have to part out the truck to attempt to recover my money and cut my losses. I would much rather give it the college try and try to get everything sorted out so I can begin restoring the truck which I plan on keeping in the family for quite some time. I looked into data tag reproduction which just requires a copy of the title but I'm not convinced that this is enough to get the truck registered in Florida. Any help in locating any hidden VIN numbers on the frame would be greatly appreciated. I'm sure this may have been discussed in other posts but I'm freaking out and have not had a chance to do a search. Thanks in advance.
jR
Old 04-11-2012, 12:29 AM
das54's Avatar
das54 das54 is offline
das54 has a good reputation on FTE.das54 has a good reputation on FTE.
First off - Welcome. A lot of good info and plenty of support here. As for getting your title and registration - as you know each state is different but the VIN is stamped on the frame and that is what your DMV should look for IF they look for one. It should be on the top of the frame rail, passenger side, probably between the cab mount and the radiator cross member. Read thru this thread. http://www.ford-trucks.com/forums/11...-engraved.html
or here
http://www.ford-trucks.com/forums/91...it-really.html
and this thread
http://www.ford-trucks.com/forums/91...-location.html
good luck hunting
Old 04-11-2012, 07:57 AM
South of BC's Avatar
South of BC South of BC is offline
South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.
Sacramento Vintage Ford or Mid-Fifties can have a new rating plate made for your truck.
Old 04-11-2012, 09:06 AM
Nighthawk756's Avatar
Nighthawk756 Nighthawk756 is offline
Nighthawk756 is starting off with a positive reputation.
Old 04-11-2012, 09:46 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Unless the DMV laws in Florida have changed a lot since I left, it's one of the easier states in which to get an older vehicle registered. If you can't find the VIN on the frame rail check with the DMV for other means of registration...
Oh, and welcome to FTE!
Old 04-11-2012, 10:38 AM
Thanks for the link Brad. Cheaper and faster indeed. MF is $125 with a 8-12 week wait (or for $40 rush service: 7-10 days), SacVin is $125 with a 2-3 week wait. Backeast quoted me $100 and done in 3 days.
Old 04-11-2012, 01:42 PM
Quote:
No problem!
He got mine to me and in my hands in less than a week including shipping time.
Old 04-11-2012, 03:19 PM
Stephen67's Avatar
Stephen67 Stephen67 is online now
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
I'm not sure how it is where you're at, but around here if a truck is old enough and has lost the title and vin plate, you can have a new VIN stamped on by the PD and go off of that. We have a lot of 'lost trucks' out in fields around here, so it's not uncommon. There are ways to get a title as well. It's a hassle but possible. This is one of those things that I would suggest taking care off before you do anything else.
I wouldn't worry about having to part it out or cut your losses, there are lots of ways with these older trucks, but you'll need to arm yourself with information as if your DMV is anything like mine, they will tell you it's not possible because either they don't know it is or don't care to do the paper work. 50 year old vehicles are a little different than say a truck from 1999, missing a title and vin usually just happens and isn't a red flag that it was stolen.
Old 04-11-2012, 08:46 PM
59JEEPSTANG's Avatar
59JEEPSTANG 59JEEPSTANG is offline
59JEEPSTANG is starting off with a positive reputation.
When I transfered my title, I just told them the truck was in pieces and I was going to fix it up. No issues. Now I did have a Florida title (issued in the 70's). Did the same for my Model A in the late 80's on a title issued in the early 50's. When I moved from NJ in early 80's transfering the titles required mileage and vin checks on my vehicles. But it is my experience it has gotten a lot easier to transfer titles on older vehicles. If it were me I would take my title to your friendly neighborhood dmv office (in proper order, signed price filled in (don't go to low)) tell them you would like to transfer the title (no tag yet) on your restoration project. I don't think you will have a problem. Just don't volunteer any more information than needed. Where are you in Florida?
Paul
Old 04-11-2012, 09:04 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Das,
I had the same worries with the 1950 F1 we bought. We changed out both axles & put in a new firewall, etc. No ID on the frame that I could find.
In Texas we have a process called "Vin Verification" where any
place doing state inspections can verify your Vin for a $1.
I made it real easy for them & put a nice tag with the same # as shown on the Title in the Glove Box. They looked at the Tag & wrote down the same mileage as shown on the Title. I took the nice Vin verification form to the County & registered the truck for $35.
Hopefully Florida has a similar process. Good luck over there!
Do you have any pics of your nice '56/'53? Don't give up due to paperwork - that's one you can get off the old todo list in a week.
Ben in Austin
1950 F1
Old 04-11-2012, 09:30 PM
Quote:
Paul
Thanks for the advice Paul, I live in Fort Lauderdale
Old 04-11-2012, 09:38 PM
Thanks for all your help guys, it's rare to find a helpful forum. Usually you find lots of idiots that enjoy picking on others from behind their computer. I decided that I will be ordering a VIN plate from A. G. Backeast but I'm not sure if I will attach it to the cab somewhere before I speak to the DMV or just go the "it's currently in pieces and has no vin on the frame route". I have a friend which is a police officer and gave me the direct number to his "DMV contact". Not sure if I should tell her everything or play dumb and go the "it's in pieces route". I'll keep you guys posted.
jR
Old 04-11-2012, 10:16 PM
I'm by no means an expert on the subject as I haven't had my plate done yet, but it seems that you can't get a plate made without documentation like a title in your name. Which, if I understood your post correctly, you don't have yet. A pencil rub of the plate helps, which of course you don't have. If you can't get the rating plate yet, don't give up. Have you looked for the VIN stamped on the frame? It should be on the top of the frame rail, on the passenger side. Mine is nest to the crossmember that holds the radiator, however another member has his further back near the crossmember of the transmission.
Old 04-11-2012, 11:07 PM
ben73058's Avatar
Hey JR,
Welcome Aboard! We spent 7 years in Ft. Lauderdale - Wilton Manors to be more accurate. Nice town..... Post some pics when you get a chance. I can see you cruising down A1A...
Ben in Austin
Old 09-15-2012, 10:05 PM
update
so it's been a while and after some frustrating hoops and red tape I finally have my antique tag and the truck is registered in my name! Time to shift into overdrive and start fixing this thing up right!! Thanks for all your help guys!!
VIN / registration dilemma 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 01-06-2015 11:19 PM
1965 F100 VIN problems. Any help would be appreciated! jrayyy 1961 - 1966 F-100 & Larger F-Series Trucks 11 07-14-2014 10:16 PM
1951 registration issues in CA.. cstovall51 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-11-2011 07:46 PM
53 f-100 VIN location bpage33 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-08-2010 01:46 PM
56 Frame VIN Number - Where is it really? Dr G 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-01-2010 12:30 AM
Tags
53, 5356, 56, cars, classic, core, f100, lost, missing, mpg, radiator, restore, support, texas, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
