Replace A/C compressor - Ford Truck Enthusiasts Forums
Old 04-10-2012, 05:23 PM
nomad221's Avatar
nomad221 nomad221 is offline
nomad221 is starting off with a positive reputation.
Compressor finally quit after 159K. Could an A/C guru please educate me as to what all is involved with installation of a new one ? I'd like to get a couple of quotes from some local shops and do not want to get burned, or, if I can, replace it myself.
Old 04-10-2012, 08:22 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Is the compressor shot? I've never done it, but you can put new clutches in it.
Old 04-10-2012, 08:35 PM
nomad221's Avatar
Quote:
The hub engages but the compressor shaft will not turn. Hub is burned up now.
Old 04-10-2012, 08:46 PM
ReBilld's Avatar
You could replace the compressor yourself, it's not a bad job, but if the system is still fully charged you'll have to have it evacuated before you unhook the manifold at the compressor. Then, unless you have access to a vacuum pump and gauges you'll have to take it some where to have a good vacuum pulled on the system and recharged after you replace the compressor.
Remove Idler Pulley-Fix A/C Binkowski 1987 - 1996 F150 & Larger F-Series Trucks 4 05-28-2016 01:28 PM
1997 E-350 A/C compressor R T 1968-2013 Full Size Vans 3 07-30-2015 11:45 AM
A.C. compressor shakes John R. Thomas 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-07-2013 11:03 PM
Smoking A/C Compressor cupins 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-14-2012 05:17 PM
replace a.i.r pump with air compressor? nebechanezer 1987 - 1996 F150 & Larger F-Series Trucks 3 05-26-2012 07:34 AM
Tags
2006, 350, 460, 73diesel, 92, ac, change, changing, compressor, f150, f350, ford, omegacompressor, truck, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
