Diesel vs. Biodiesel Fuel Mileage
I recently found a station that sells diesel with "up to 20% bio", B20 I guess, right? It is a little bit cheaper, so Im wondering what the trade off is.
Has anyone compared the mileage they get with Bio compared to regular diesel? If it is anything like ethanol-flavored gasoline it is a considerable decrease in mileage and not worth it. (Of course ethanol is actually bad for gas engines on top of it.) I know Bio offers some lubrication benefit so thats good. Am I better off sticking with regular diesel or alternating or what?
Assuming mileage is less with Bio, I guess it would depend on how much less it costs to see if its worth it. This particular station was selling B20 for about 10 cents less per gallon than my normal station, if I remember correctly.
Here is a picture of the 11" CAT filter (not my picture though)
I used B20 for several years, and I never noticed any difference in mileage. My truck seemed very happy with it. As stated, make sure you don't get a gunked up fuel filter due to the bio cleaning out your system. Never happened to me, but I've heard where it's happened to others-
I just recently stopped using it exclusively simply because the B20 pumps are a little too far away to be convenient. Like you, I liked the idea of added lubricity in the fuel.
I think theoretical drop in mpg for biodiesel is about 10%, so running B20 you'd loose 2%. Not enough difference to measure.
Than it is common on topics where owners of cars design to run on Premium -use regular on them saying their mpg has raised. This is easy to explain, running on worse fuel makes the engine performing less, meaning less acceleration. Less acceleration gives better mpg, what might compensate for lower mpg on flat driving.
Lot of manufacturers advise using B5 on older diesel to get a lubrication lost in fuel by cutting down on sulfur. Even I don't have bio stations in convenient for me areas, I like to put some of it once a year as a cleaning solution. Never had filter plug with it, when last filter lasted me for 80,000 miles.
I think I am gonna switch over to B20. I had been using Diesel Kleen pretty regularly, mainly for lubricity, now I can not spend the money on that and save a little on the Bio! Its a win-win!
I dont even know what the intank mods are yet. I have seen them mentioned around here and feel sure it is probably the next thing I start researching.
The harpoon mod will just allow you to rapidly and completely fill your fuel tank.
XBAJBUSX
17
05-01-2010 10:06 AM
smoky_diesel
06-27-2009 12:07 AM
Robert6401
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-27-2007 10:36 AM
