HELP!!! Bedplate leak
My oil cooler and EGR cooler were both in good shape, so I didn't replace them. You don't have to pull the motor to do those two, so I figured I could change them later if needed. The STC fitting is between the high and low pressure oil systems... not sure when they redesigned it, but mine was the older, more trouble prone design, so they switched it out.
I have had zero problems with the truck since the repair.... no leaks or anything else. You can't tell that the engine was removed; my dealer did an excellent job on everything. I may take it to them when it is time for studs, but I don't know if I'll be able to afford them.
I just bought an 06 with the same issue. At the time I thought It was a rear main until I saw it comming from the back of the bedplate. I just changed the entire bedplate because It turned out to be cracked on the top(dont ask me how). I found 1 dealership in California (Im in Indiana) who did the job by removing the transmission. I did mine in my shop. It took me a weekend, but it CAN be done by removing the trans. I wouldnt recommend doing it any other way. The transmission, other than being heavy(when pulled with the transfer case) is fairly easy to remove. I would find a place that is willing to do it for you that way. My pockets arent deep enough to have the engine removed for something like that. Just my 2 cents...
And I agree with the OP. The only PROPER way to repair a bedplate leak is to R & R the engine and flip upside down on an engine stand to do. Anyone that tries to tell you otherwise is full of it. This is the way I'd be doing it, if one were to show up on my doorstep. I have R & R'ed probably too many cabs on many Ford vehicles too numerous to list here, and NONE have come back with issues related to the pulling of the cab so far, so I'm having difficulty catching onto what the OP's concern is with having his cab pulled for repair.
What scares me is 4 months ago, same leak, the dealership insisted it was oil pan gaskets so they replaced them. Then 1 month ago I still see the leak, this time they said its a crank sensor, warranty is up thats $200 to fix. I went back and spoke the service rep now they pulled the starter and said,.oops its a bedplate. We made a mistake so we will cover it.
Same dealership did my head gaskets at 17000 miles, they would not install arp head studs unless I agreed to void 100% remaining and current repair warranty once installed.
If it was me, I would accept their voided warranty(with at least a week or two grace period to make sure the fix they are about to do holds), get the bedplate fixed and pay for new hg and get the studs in. might have to do some talking to get it done, but that is a no brainer to me. Basically, do you want an oil leak,,,, or not.
If your a ford tech, whats your opinion on it. Its a seep, wet behind the starter and wet on the tranny bell housing. No drips, no oil leaks, no oil use. My first thought was to leave it alone. 2 stroker made some suggestions, like a coolant filter. That I am definetly installing asap.
Does the OP have a tuner or anything in the truck?
I I were in his shoes I don't think I would bother with pulling the heads again and dealing with that. I would have the bedplate fixed and move on with life.
My dealer replaced several sensors before finally finding that the leak was the bedplate. It's been almost a year and a half though now and I've had nary a problem (nor any new leaks). Since I'm out of warranty now, I don't think I'd pay to have the leak fixed (the dealer showed me the ~$3k bill they sent to Ford), but I'm glad I had it done while I was still covered.
#30
When your headgaskets were done at 19000 miles did they lift the cab.
I had a hanging oil drip on the bellhousing at 58000 miles that started as a seep about 40000 miles earlier. With only a couple weeks left on the warranty i took the truck in and got a diagnoses that the rear main seal is leaking. I gave the ok to replace the seal.
The next day i call asking when the truck will be ready to pick up and to my surprise i hear "the tech has your engine out and is replacing the bedplate gasket" There was a short pause on my end and then i replied I'M ON My WAY
On the way to the Dealer my wife calmed me down some but when i seen my cab 6' in the air, my engine next to the truck, wires, hoses hanging and fluids on the floor i was sick
After a talk with the tech i was OK with the work (just wished they would have gave me a heads up before starting)
While it was torn down i had the headgaskets and studs done just to hopefully avoid having the truck torn apart this far again.
Its been about 35000 miles with no leaks and your never know the cab had been removed.
