Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-10-2012, 02:46 AM
E150 4.9 1990 E150 4.9 1990 is offline
1990 Ford E-Series Van
E150 4.9 1990 is starting off with a positive reputation.
Why is the E250 5.8 weaker than the 1995 E250 5.8?
The 95 has 240HP and 340ft.lbs. The 95 only 210HP and 325ft.lbs. The 95 revs higher. Its peak HP comes at 4200. The 96 only 3600.
Only the fuel + ignition map of the vans are different or there are mechanical differences too?
Is it possible the get a chip or something which brings the old power?
Would it have any disadvantages? I mean worse mpg or whatever.
If I am right at 96 there was a system switch, the 96 is already OBDII so a simple ECM unit change doesn't go...
I am so curious, how it would drive with a little more aggressive setup!
Tags
1995, e250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
