Cam Phaser Lockout Installed and Running Very Quite
#94
#96
I say you are LUCKY. You had your chain jump and didn't get an interference call from the referee. Yep lucky . . .
Holy crap, duct tape for the win!
So the question remains. What causes the chain guides to break on these engines?
Any takers?
Andy
#97
cam phaser lockout
I have been chasing this one I have 60 psi oil pressure we have out new vct sensors in, new chains guides, crank sprocket ,tensioners, plugs. The truck starts good, but you never know when it will start the missing and no power. What do I check next and do you think the cam phase lockouts will help. I lock my 4 door 4x4 short bed lariat but it would be helpful if it was not a fixture in my garage
#99
#100
#103
#104
Update time again. Its been about 5 months since I had to replace the timing guides and tensioner because of their failure, and all is well with my 3V. I actually helped a friend with his engine noise issues and his plastic tensioners show signs of leaking around the gasket too. I recommend to everyone who ever gets this deep into their cam timing to replace the junk plastic tensiondrs with iron (1998 or so f150). With thephaxers locked and tensioners working, I promise my 5.4 is the quietest 3v you've eved heared.
Andy
Andy
#105
Why the guides break.
Andy
Found this site and the explanation make sense to me. what do you think?
AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - Symptoms of Bad Timing Chain, Ford V8 Engines
Gary
Gary
