I need a inline fuel filter system, 1995 7.3
Maybe a rundown issue but I am in a quagmire here with my 1995 f350 cc dually 7.3 rwd stock stump puller.
I have lloked at dieselsite, fass, airdog2 and met a guy in lakeland fl with a nice homedun fuelbowl delete electric pump remote fuel filter setup. I did nont invent the wheel and I need help with ideas on what to do. My fuel bowl has been clogged at the inlet, and my tanks are coming down. So if you wanted to go mid range cost, what would you do, and please guru's, dont tell me where to post it, Thanks. CPR is the top choice and I just need plug and play. I own nuttin but fords, and that is my greatest source of pride,
Agreed with Nate.
Personally I would rather do a DIY since it is basically plug and play anyway with all the writeups out there. I think it was TJ who had his e-fuel writeup. It was a full e-fuel setup and he had part numbers and everything listed.
So basically order all those part numbers he listed and put it together.
But if you want to spend the $$$ its your truck and your money. lol
Good luck!
Good luck!
hilljackusmc
12-12-2007 07:26 PM
