2005 F150 problems
Old 04-09-2012, 07:30 PM
Skullver's Avatar
Skullver
Skullver is offline
2005 F150 problems
I have a 2005 F150 5.4 and I recently got a p0175 code. I've replaced the M.A.F. sensor, fuel injectors, fuel filter, new plugs, coils and checked the vac lines but I'm still getting a p0175 code. Ive reset my P.C.M. and the code stopped for 2 weeks but returned later. The truck runs fine when I erase the code but when it returns it hesitates on take off and has a slight shake like a misfire and it makea a bubbly popping sound from the exhaust. Im at a loss of what to do next! Could this be a code stuck in the P.C.M.? My mechanic thinks it mya be the cam phasers! Pls someone help!
Old 04-09-2012, 08:47 PM
GwarForAll1021's Avatar
GwarForAll1021
GwarForAll1021 is offline
Sounds like you might have fried the cats. Magnaflo sells some replacements cheap.
That's my .02
Old 04-09-2012, 08:50 PM
Skullver's Avatar
Skullver
Skullver is offline
Thanks I'll take a look at that!
Old 04-12-2012, 05:33 PM
Skullver's Avatar
Skullver
Skullver is offline
Got new codes
So I went and got a code test ran and now it says I have p0172 and p0175 code. Any ideas?
Old 04-12-2012, 08:38 PM
Coskid's Avatar
Coskid
Coskid is offline
Did you check out your cats are they OK?
Also check your O2 sensors I didn't see where you mentioned anything about them.
Old 04-14-2012, 04:35 PM
Skullver's Avatar
Skullver
Skullver is offline
I replaced 1 o2 sensor but none of the others. I havent had the cats check yet.
mysuperduty89
Modular V8 (4.6L, 5.4L)
02-22-2012 06:15 PM
beartracks
Computer Chips & Tuners
08-23-2011 05:13 AM
raptor2005
02-15-2010 03:03 PM
Quick Reply: 2005 F150 problems
