Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 04-09-2012, 05:12 PM
Regulator1988's Avatar
Regulator1988 Regulator1988 is offline
2003 Ford F-250
Regulator1988 is starting off with a positive reputation.
Which to buy
Sct Tuner which turns off the EGR so i dont need a Delete Kit
OR
Edge Evolution
__________________
2003 F250 XLT 4 Door Long Bed
LT 265/75/16 Goodyear Silent Armor
Dura-Stroke Turbo Built by Adrian,Warren 175CC Injectors, AIR DOG 2, EDGE CTS Programmer, 4in Diamond Eye Straight Exhaust, S&B Intake, ARP Studs, New Oil Cooler 8/12, BPD EGR Delete, Blue Spring upgrade, SCT Custom Tuned, FICMrepair.com's Atlas 40 tune
  #2 (permalink)
Old 04-09-2012, 10:13 PM
pmoney1983's Avatar
pmoney1983 pmoney1983 is offline
2004 Ford F-250
pmoney1983 is starting off with a positive reputation.
Quote:
OR
Edge Evolution
The SCT Tuner does that?! I didnt know that. How much is it?
  #3 (permalink)
Old 04-10-2012, 10:21 AM
2003 Ford F-250
379 or somethibg
  #4 (permalink)
Old 04-10-2012, 10:40 AM
OZX1's Avatar
OZX1 OZX1 is offline
2004 Ford F-Super Duty
OZX1 is gaining momentum as a positive member of FTE.OZX1 is gaining momentum as a positive member of FTE.
Quote:
It can with the custom tunes; however, it does not have any bearing on the EGR delete kit. That kit deletes the EGR pipe/cooler, etc. Not the EGR valve.
  #5 (permalink)
Old 04-10-2012, 10:52 AM
raptor131's Avatar
raptor131 raptor131 is offline
Garage is empty, add now
raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.
OR
Edge Evolution
The egr delete kit's primary function is to remove the possibility of egr cooler failure from a badly clogged oil cooler. Then you purchase the tuner to eliminate the check engine light on certain MY trucks. Or trucks that have gotten the latest strategy from the dealer.
__________________
05' silver f-350 lariat 6.0 psd 4x4 crew cab drw, 4"inch turbo back exhaust, BPD oil cooler condenser mount, powermax turbo,dc power 190Amp OEM High Output Alternator , coolant filter, auto meter: boost, coolant temp, trans temp, egt, voltage. scan gauge II, Rds 91 gallon fuel tank toolbox combo, ready lift 2.5 leveling kit, blue spring mod.Fumuto oil drain, AE w/ford enhanced bundle.Air lift 5000 series rear air bags
  #6 (permalink)
Old 04-10-2012, 01:24 PM
OZX1's Avatar
Quote:
So get the SCT & The EGR delete
__________________
Brian
Torque is addictive
  #7 (permalink)
Old 04-10-2012, 01:46 PM
raptor131's Avatar
If you want to delete the egr system go with a kit to delete it. Then get the sct to eliminate the check engine light depending on MY. I deleted my egr cooler and left egr valve plugged in and haven't gotten a cel. I have heard of others doing this and getting a cel so they bought the tuner to eliminate the cel. I was just trying to set you right. The comment you started with made me think you wanted to get the tuner just to eliminate the egr.
__________________
  #8 (permalink)
Old 04-10-2012, 03:19 PM
pmoney1983's Avatar
2004 Ford F-250
Thank you for clearing that up. Thats what i was thinking when he stated that. Tripped me up. Thanks.
  #9 (permalink)
Old 04-10-2012, 07:44 PM
2003 Ford F-250
Oh I did. I thought if you did that you wouldn't have to do the egr delete
  #10 (permalink)
Old 04-10-2012, 08:18 PM
Dbergeson Dbergeson is offline
Dbergeson is starting off with a positive reputation.
EGR
How bad is it to have the EGR deleted? I hear people talking about it all the time on here. My mechanic told me mine was DONE and stuck. Time for a new one. I asked about doing a delete kit and he said that's mainly for OFF ROAD use and that at some point I would get to HOT and real mess things up.
Opinions and concerns? I am fairly NEW to Diesels, and want to know what's best. I have 3 out of 4 injectors bad on one bank as well.
What's my best bet for injectors and EGR valve?
Thanks,
Don
Tags
check, delete, egr, engine, ford, light, sct, tuner, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
