Coolant Leak
Coolant Leak
Just noticed a coolant leak today. Coming from the area of the Vertical EGR. I'm pretty meticulous on maintenance and checking fluid, so this just started within the last 24 hours. Here are the pics.
Top engine view looking down vertical EGR Cooler. Radiator bracket is at the bottom right.
<a href="http://s68.photobucket.com/albums/i34/westwoodlands/?action=view&current=780cd6ab.jpg" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/780cd6ab.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"></a>
Looking up from under truck. Front of truck is towards the bottom right of the picture.
<a href="http://s68.photobucket.com/albums/i34/westwoodlands/?action=view&current=31c58645.jpg" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/31c58645.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"></a>
I did have a bubble pass through degas bottle after opening lid.
Well, I can't give too much info as to whether or not the rad hoses, o-rings, radiators, etc are covered past 3/36. I have the Ford ESP maintenance plan which covers all wear items so the hose is covered. But initially, the SA said it wasn't covered past 3/36. Didn't bother arguing once he said my ESP covered it.
Turned out to be the upper hose which happened to drip perfectly on the lower hose engine sude connection which made me think it was the lower hose.
Just some useful info though, my ESP warranty only pays ~$100 for parts and labor, so it shouldn't be too horrific if you had to pay out of pocket.
The dealer told me that they had replaced the “o” rings with the update kit when they had the cab off for a “bed Pan” oil leak that was repaired @15,000 miles on a 08,6.4.
Why don’t they just replace with old fashion hose clamps that worked for years ??? Can you install hose clamps on this “O’ ring set up that Ford has come up with ??? <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
