1995 7.3 Powerstroke won't start - Ford Truck Enthusiasts Forums
Old 04-09-2012, 04:06 PM
Powerstroke1995 Powerstroke1995 is offline
Powerstroke1995 is starting off with a positive reputation.
I've got a 1995 F250 with a 7.3 powerstroke, and it had 298,000 miles on it when one day I was driving down the road and it just quit. It was as if someone literally turned the key off, as it did not make any noises or act in a way that would suggest something was going wrong, it just shut off immediately. Now, it just cranks, and won't even attempt to fire. We put a new cam position sensor on it to no avail, and checked the fuel flow and it was fine. Our mechanic friend told us it might be the PCM....which i know nothing about. Anybody have any insight? Much appreciated.
Old 04-09-2012, 04:25 PM
bryanlindborg600's Avatar
bryanlindborg600 bryanlindborg600 is offline
bryanlindborg600 is gaining momentum as a positive member of FTE.
got a wait to start light? does it come on and go off like normal?
Old 04-09-2012, 06:01 PM
terryknight's Avatar
terryknight terryknight is offline
terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.terryknight has a great reputation on FTE.
check fuse number 22 under the hood. it is for the fuel heater in the bowl and controls power to the pcm. if the fuel heater shorts it'll blow the fuse. if it is blown unplug it from the bowl, replace the fuse drive as normal. don't worry about the fact that the heater is not plugged in
Old 04-09-2012, 08:36 PM
Andy Sullivan's Avatar
Andy Sullivan Andy Sullivan is offline
Andy Sullivan is starting off with a positive reputation.
Like said check the fuse. Had mine blow cause by the heater element in bowl under filter. Pull filter and look inside to see if the metal wire element is move around if so that is it. Or like said just pull wire and replace fuse.
Old 04-10-2012, 12:32 AM
Should also ask if the truck has a chip? A lost/ bad connection with the PCM can cause the same symptoms...
Old 04-10-2012, 10:56 AM
msmenne17's Avatar
msmenne17 msmenne17 is offline
msmenne17 is gaining momentum as a positive member of FTE.msmenne17 is gaining momentum as a positive member of FTE.
What color CPS did you get? I've read where they can be bad out of the box. If you got a gray one, find a black one. Once you do get it started, the gray one will be shot within 6 months.
I had issues with my VSS shutting the truck down on the highway. Mine always restarted though without my intervention.
Old 04-10-2012, 07:03 PM
BUCKEYE286 BUCKEYE286 is offline
BUCKEYE286 is starting off with a positive reputation.
WONT START 7.3 TURBO DISEL
1994 PSTD CHECK FUEL FILTER, WHY U GOT IT OUT CHECK THE HEATER DISK UNDER THE FUEL FILTER,NOTE IT HAS LEFT HANDED THREADS 7/8 CLAW WRENCH UNPLUG THE WIRE DRIVERS SIDE FUEL FILTER HOUSING UNPLUG IT ITS A RED WIRE WITH A GREEN STRIPE ON IT. TRY TO START.
Old 04-17-2012, 02:06 PM
None of the fuses were blown when the truck died. And the truck is not chipped.
Old 04-17-2012, 02:07 PM
And I can't confirm if the Wait to Start light was acting normal, I wont be near the truck for a few days.
Old 04-17-2012, 02:11 PM
sorry, i probably should have just asked if you just got a wts light..
Old 04-17-2012, 02:39 PM
So, what would the problem be if the wait to start light doesn't turn on? And if it does?
Old 04-17-2012, 03:00 PM
as said above, no wait to start light means no power to the pcm, and fuse 22 under the hood powers the pcm as well as the fuel bowl heater which is a common problem of shorting out and thus no power to pcm and no start.. if you have a wts light, as asked above, you may want to look at your cps again... does the tach. bounce when cranking? you have checked fuel pressure?
Old 04-18-2012, 04:48 AM
Quote:
check #22 fuse under the hood,it plugs in to the d/s of the fuel filter resavor/canister its a red wire with a green stripe, it runs the fewl heater, dont need it above 39 degrees but you will need to install a new fuel heater its a round disc under the fuel filter /remove filter and center plastic guide ,use a 13/16 crows foot wrench and REMBER ITS REVERSE THREADS ,,,LEFT HANDED THREAD EMAIL ME AT BUCKEYE286 AT YAHOO.COM , I CAN FILL YA IN ON A LOT ABOUT THE 7.3 T/D
Old 04-18-2012, 08:49 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Quote:
The fuel bowl heater is really a fuel filter warmer. It's purpose is to warm the filter to help fuel flow through the filter better.
Old 04-30-2012, 12:20 PM
Fuse 22 was never blown. The CPS that we got was grey, but i haven't gotten a different one to test that theory.
1995 7.3 powerstroke cranks won't start Smidty94 1987 - 1996 F150 & Larger F-Series Trucks 5 01-20-2017 12:04 PM
1995 7.3 powerstroke not firing on driver's side Countryboy1973 1987 - 1996 F150 & Larger F-Series Trucks 8 01-02-2016 06:19 PM
1995 powerstroke engine in 1997 truck towsrus 1994.5 - 1997 7.3L Power Stroke Diesel 27 10-29-2015 10:08 PM
1995 F250 powerStroke shakker17 1994.5 - 1997 7.3L Power Stroke Diesel 3 06-02-2015 08:26 PM
New Member, New PowerStroke Motroo New Member Introductions 3 06-03-2014 09:19 PM
Tags
1995, 1997, 250, 73, 73l, 95, cranks, ford, fuses, power, powerstroke, pull, start, stroke, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
