isspro Ev2 size?
2 1/16" is the standard size for the diameter of the smaller gauges like the ISSPRO EV2's. That's pretty much an industry standard.
There are other sizes as well (3" for semi's and such and 3 3/4 for surface mounted gauges) but the vast majority of the gauge pods used for applications like ours are for 2 1/16" gauges.
Here:
http://www.isspro.com/catalog/ISSPRO...log%202006.pdf
Check out pages 3 and 4.
Here:
Auto Meter 2204 - Auto Meter Gauge Mounting Cups - Overview - SummitRacing.com 2 of these are going to be going in.
3 actually, need one for the Scangauge. My redneck mount is a little flimsy.
Look the pic.
Thanks to both for the coment of the wood grain, it is a sticker from a roll I bought for my Wagoneer, I made a template with cardboard and then cut the sticker. I just bought one Eddie Bauer (spel?) long bar (with wood grain original) for the right part of the dash, Ill put a pic later if I remember
To mount it in the same spot as mine, you will have to have a standard trans, but you can mount it on the other side of the column in about the same spot and it wouldn't obstruct the dash much, if any. That's where my next one is going.
