Power window problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-09-2012, 12:12 AM
SGorman13's Avatar
SGorman13 SGorman13 is offline
SGorman13 is starting off with a positive reputation.
The problem is on the drivers side window. When i press the button once and the window starts to go down automatically it stops about halfway. I don't have any problems when i hold the button down, the window will go up and down. Also, i have noticed that the window takes a little longer to go up than the passenger side. Anyone have any ideas as to what the problem is? thanks
Old 04-09-2012, 08:05 PM
07 F250 Aggie Mobile's Avatar
07 F250 Aggie Mobile 07 F250 Aggie Mobile is offline
07 F250 Aggie Mobile is starting off with a positive reputation.
Hope you find an answer, cause I am having the same problem!!
Old 04-09-2012, 08:20 PM
PA-Mark's Avatar
PA-Mark PA-Mark is offline
PA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputationPA-Mark has a superb reputation
Lube the door tracks to help the slow windows, as for the one that stops half way in auto, it may be the switch
Old 04-09-2012, 08:52 PM
SGorman13's Avatar
do you think the switches need replaced or maybe a loose wire? and would i have to disassemble anything (besides the door panel) to lube the door tracks?
Old 04-10-2012, 10:34 AM
PA-Mark's Avatar
no i dont think its a loose wire if it happens every time. i cant remember excaticly how the switch works but the window stops working when it encounters resistance, current draw is raised because the window motor has to work harder to to push past the resistance. that raise in current draw is what switches it out of auto down. this all happens extreamly fast. It sounds like a switch to me. it still may not be, I can be wrong. but its the only thing that makes sence. As far as lubeing the tracks, door panels, then the moisture barrier, and you should be golden
2001 F250 window problems 6 or 10 1999 to 2016 Super Duty 1 08-24-2015 09:02 PM
Ranger passenger window not rolling down Jt00 Ranger & B-Series 5 08-19-2015 10:33 AM
2003 Explorer passenger front window will not close fosterslager Explorer, Sport Trac, Mountaineer & Aviator 1 01-08-2012 01:49 PM
Power window controls david49892 Ranger & B-Series 6 09-25-2005 03:25 PM
Power Window Problem 1998 F-150 Carp824 1997 - 2003 F150 5 09-28-2004 09:48 AM
Tags
86, driver, electric, f150, f250, f350, f450, ford, power, problem, problems, side, troubleshooting, truck, van, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
