1951 F1 Cowl Vent Seal
Hello all,
I was going to change the rubber cowl vent seal and im not sure where to start. I started removing the old one but it is coming out in 100 pieces since it is so dryrotted. It looks like there is a metal retainer held down by some phillips screws. To remove all of these it seems as if the vent lid needs to be removed.
Am I on the rigth track?
Hello all,
New gasket gets sandwiched between the vent and cowl.
Here's a tip for you, and one I've forgotten several times when removing vent lids; You don't have to take the screws all the way out. You only need to loosen them a bit, as the holes in the vent assembly are slotted, and just move the lid so the screw heads line up with the big part of the hole and lift it off.
49willard
11-20-2013 10:23 AM
Woodsman_30350
07-26-2008 08:29 PM
Matt Scassero
05-26-2004 06:18 PM
