2008 factory remote start problem
I installed a factory remote start, keyless entry, and alarm. Part # 7L3J-19G367-AA. I have everything wired locks and unlocks work, programmed the way it says to but when I hit the start button. It goes in to start mode but doesn't crank. PATS module is hocked up and working no security light is on. I can start the truck with the key hit the remote start button turn the key off pull the key out and the truck stays running. Any help would be appreciated.
Did you have both keys when you programmed the PATS? I know this was an issue when I did mine. You have to have them both to program the remote start correctly.
Also, I wish I had just gotten an aftermarket one. The "factory" Ford remote start and alarm kit is an aftermarket one with a Ford sticker on it.
Did you have both keys when you programmed the PATS? I know this was an issue when I did mine. You have to have them both to program the remote start correctly. <br />
<br />
<br />
<br />
Yes I have both keys.
I have no power out on that wire during remote start but it does show power when I crank with the key.
OEM remote start
Hi
I have no definitive answer but you must check your hood pin or any other connection which are crucial. I have used them in non ford vehicles.
This time I am also installing an OEM starter on 2009 escape. I am unable to locate wiring for following can you please help....any images, would be of greater help...
1.Door Lock output
2.Door Unlock output
3.Park light output
1.Door Lock output
3.Park light output
I have 2008 and 2010. hope this helps
#512266: 2008 FORD ESCAPE 4DR SUV
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Please select another category
Security
Battery BLUE/RED (+) IGNITION SWITCH
Ignition 1 WHITE/ORANGE (+) IGNITION SWITCH
Starter 1 BLUE/WHITE (+) IGNITION SWITCH
All Door Trigger GRAY/VIOLET (+) DRIVERS KICK PANEL
Domelight Super BROWN (-) DIMMER SWITCH
Parking Lights VIOLET/WHITE (+) DRIVERS KICK PANEL
SMALLER PLUG IN D. KICK PANEL
Low Crr Pk Lights BLUE/GRAY (-) IGNITION SWITCH
IF THE VEHICLE UIS EQUIPPED WITH AUTO LAMP USE MUST USE TWO RELAYS ONE ON PARKING LIGHTS AND THE OTHER ON HEADLAMPS. IF VEHICLE DOES NOT HAVE AUTOLAMPS THEN ONLY ONE RELAY IS REQUIRED AND THAT WILL BE ON JUST THE PARKING LIGH WIRE. SEE TECH TIP.
Convenience
Headlights-Lo YELLOW/BLUE (+) HEADLIGHT SWITCH
Trnk Release BROWN/BLUE (+) REAR DRIVERS SILL PLATE
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH
Key Sense BLUE/GRAY (+) IGNITION SWITCH
Speed Sense PURPLE/ORANGE, 8000 PPM (AC) UNDER HOOD ON FIREWALL 3 CONNECTOR PCM MIDDLE CONN. POSITION 1
Low Crr. Pk Lights BLUE/GRAY (-) IGNITION SWITCH
Brake Lights GRAY/BROWN (+) LOCATED IN THE SJB (DRIVERS KICKPANEL)
Horn BROWN (-) STEERING COLUMN HARNESS
Modules
WIRE LOCATION
Module 1 SJB-SMART JUNCTION BOX LOCATED ION DRIVERS KICK PANEL
Doorlocks/Windows
Door Lock Circuit 3 WIRE NEG
Power Unlock YELLOW/VIOLET (-) DRIVERS KICKPANEL
PowerLock BLUE/GREEN (-) DRIVERS KICKPANEL
Driver Mtr Unlock BLUE/GREEN (+) DRIVERS KICKPANEL
Driver Mtr Lock GRAY/BROWN (+) DRIVERS KICKPANEL
Pas Mtr Unlock VIOLET/GRAY (+) REAR DRIVERS SILL PLATE
2010 vehicle wiring
PATS RX Data ~ Purple/Grey At transponder Connector (PIN 4)
PATS TX Data ~ Yellow/Orange At transponder Connector (PIN 3)
PATS Ignition + Blue/Tan At transponder Connector (PIN 1)
PATS Ground -Black/Blue At transponder Connector (PIN 2)
12 Volts 1 + Blue/Red Ignition Harness
Ignition 1 + White/Orange Ignition Harness
Accessory 1 +Purple/Green Ignition Harness
Starter 1 + Blue/White Ignition Harness
Parking Lights + Purple/White Driver Running Board Harness
Foot Brake + Purple/White At Driver Kick Panel
Emergency Brake - White/Purple At Emergency Brake
Clutch Switch - Blue/Orange At Clutch Switch
Lock - Blue/Green At Driver Kick Panel
Unlock - Yellow/Purple At Driver Kick Panel
Arm + Yellow/Green and Purple/Green Diode isolate In Drivers Running Board Harness
Disarm - Purple/Brown In Drivers Running Board Harness
Trunk Release - Brown At Smart Junction Box Located in the center console
Lift Gate Release - Brown/Yellow Driver Running Board Harness
Dome Sensor -Grey At pillar
Door Pin FL -Green/Purple At Smart Junction Box
Door Pin FR -White At Smart Junction Box
Door Pin RL -Green At Smart Junction Box
Door Pin RR -Yellow At Smart Junction Box
Trunk Pin - Grey/Orange At Smart Junction Box
Horn - Brown Steering Column
Key Sense + Blue/Grey Ignition Harness
Tach ~ Purple/Brown At PCM module under hood
Fuel Injector ~ Any Fuel Injector Opposite from Green/Red
Reverse Lights + Green/Blue In Drivers Running Board Harness
Fuel Pump + Purple/White At Passenger Kick Panel
Rear Defrost - White/Orange Back of A/C Module
Auto Lights Shutdown (cut) Purple/Green At Parking Light Harness
Audio/Mobile Video
Security
Convenience
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
2010 vehicle wiring
did you troubleshoot.....hold remote start for 3 10 secs....horn chirps....the number of horns should tell you the problem....i guess your security by pass not programmed properly.....
1 chirp...security
2 chirp hood or brakes
3 chirp door
4 chirp...tach....
i hope this helps
Hi did you get your remote start to work .....i did mine and works...
1 chirp...security
3 chirp door
4 chirp...tach....
i hope this helps
1 chirp...security
3 chirp door
4 chirp...tach....
i hope this helps
In summary, your installation has been good but need to program.....give a try by making it learn the tach mode...you never know....I had to spend a long time setting my security bypass...it took me atleast 8 attempts over 3 days....just the programming....
Option Bank 1 – 4 chirps
1 – Lite-touch adjustment (refer to page 25 for Shock Sensor programming procedure)
2 – Full shock adjustment (refer to page 25 for Shock Sensor programming procedure)
3 – Learn tachometer
With hood open or brake on, start engine. System will chirp horn every five seconds
if a valid tach signal is present. Press Panic on transmitter when complete.
4 – Door ajar switch input inverter
LED On – Positive, LED Off – Negative .................................................. .................................................. . On (Positive)
5 – Unlock switch sense input inverter
6 – Key-in sense input inverter
7 – Extended Horn Honk Pulse
LED On = Extended Horn Honk Pulse, LED Off = Standard horn honk pulse .......................................... Off
8 – Optional alarm disable
Disables security functionality. .................................................. .................................................. ............... Off
Option Bank 2 – 5 chirps
1 – Starter Interrupt
Starter interrupt activates when Security System is armed. .................................................. .................... Off
2 – Passive starter Interrupt
Starter interrupt activates 1 minutes after key off event. .................................................. ........................... Off
3 – Passive arming
Security system activates 1 minutes after key off event. .................................................. .......................... Off
4 – Passive door locks
All doors lock automatically 1 minutes after key off event. .................................................. ...................... Off
5 – Selectable chirps
Enables arming/disarming confirmation chirps (uses horn). .................................................. ................ On
6 – Silent choice (Requires option #5 (above) to be ON)
On – Confirmation chirp on second press of transmitter button
Off – Confirmation chirp on first press of transmitter button .................................................. ................... On
7 – Door Ajar Input Entry Delay
5 Second entry delay. Used for vehicles with external door mounted RKE keypads................................ Off
8 – Use trunk relay as Driver door unlock
Switches Trunk release and Drivers door unlock outputs .................................................. ...................... Off
Option Bank 3 – 6 chirps
1 – Drivers door priority unlock
Drivers door only unlocks on first press of Disarm/Unlock,
All doors unlock on second press within 5 seconds. .................................................. ................................ Off
2 – Ignition lock
All doors lock when ignition key is turned to on (run). .................................................. .............................. Off
3 – Ignition unlock
All doors are unlocked when ignition key is turned to off. .................................................. ........................ Off
4 – Delayed door lock for ignition lock
Waits 3 seconds after key on event before activating ignition lock.
Used on vehicles with theater dimming interior lights. .................................................. ............................. Off
5 – Illuminated exit
Activates dome light output for one minute when ignition key is turned off .............................................. On
6 – Horn used for alarm
Horn sounds during alarm/panic cycles .................................................. ................................................. On
7 – Noise control
Limits alarm trips to 5 per zone .................................................. .................................................. .............. On
8 – Factory RKE system does not arm alarm
Prevents factory RKE from arming security system. Still allows
factory RKE to disarm security system. .................................................. .................................................. . Off
Not starting
On my 2008 Ford F350, I have the factory remote start. When I first got the truck at 72000 miles it worked great. About 2 years ago it quit working, it comes on like it's going to start be the theft light flash rapidly. The horn chirps when I press the button and chirps again when it doesn't start. Any thoughts what it might be?
