1997 F150 low idle - Page 2 - Ford Truck Enthusiasts Forums
1997 F150 low idle
Old 05-07-2003, 09:27 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
1997 F150 low idle
As a post-check, verify correct alignment of all timing marks.
I'm assuming you know how the tensioners and guides go together
Old 05-08-2003, 11:16 AM
kjester kjester is offline
kjester is starting off with a positive reputation.
1997 F150 low idle
Thanks so much, this is great info. I really appreciate the time it took you to provide this. I will be tearing it apart this weekend and will let you know the out come (keeping my fingers crossed).
Old 05-14-2003, 02:35 PM
1997 F150 low idle
The cam was off by one tooth. I checked the compression before putting the timing cover on and it went from 125 PSI to 155 PSI. After putting it all back together, the truck ran great. Next time I will take the extra 5 minutes to verify the timing.
Racerguy - thanks for all your help and providing the pictures.
Old 05-14-2003, 09:59 PM
Racerguy's Avatar
1997 F150 low idle
Good to hear you got it fixed and thanks for letting us know what you found
Old 04-09-2010, 03:02 AM
Monaco Monaco is offline
Monaco is starting off with a positive reputation.
Hello,
I will also thank you for the Info. But I'm still not 100% sure, sorry.
Is your description for both sides?
This would say, that the cam sprocket/tooth with the timing mark from the left and the right cam are always between the Links of the chain.
And the crank sprocket (at 6 o'clock) is for both sides on a bright link?
Just asking, but
if I get your description right it seems that the RH camshaft (passanger side) on my 4.6L Windsor is not set correctly - the chain is with the bright link on the cam timing mark tooth and not between???
<style></style>Would very appreciate if you may got the time to clarify/confirm. I will be tearing it apart this weekend and want be sure that this time everything will be set 100%
Thank you in advance and sorry for the inconvenience it may cause.
Have a nice weekend!!
Old 04-20-2010, 01:54 AM
timing the chains on a Modular Windsor 4.6l
Just in case that sombody is interested in setting the Camshaft on the 4.6l Windsor Engine<o></o>
<o></o>
I checked the timing on my 97`Windsor Engine last weekend and the descriptions (Haynes/Chilton’s/Ford Service Manual) I got, are all not 100% compatible.<o></o>
So I used the “Ford Service Manual” that tells you to fold the Chains in halve and mark the end links (see pic A0041106 in this Thread),<o></o>
<o></o>
well they showing that one end is a bright Link and on the other side there is a slot – this is definitively wrong.
The Chains having 58 links – 29 links each side, that means you got the bright links on both sides (Crank and Cam) or two slots – depends how you fold them. <o></o>
<o></o>
I folded the <o></o>
RH Chain with the bright links on the timing marks and the <o></o>
LH Chain with the slots on the marks.<o></o>
<o></o>
After marking the end links - I set the Cams – Crosschecked it with the Haynes/Chilton’s Manual – resold<o></o>:
<o></o>
LH Cam is exactly at 11 o’clock from the straight surface from the Cylinder head, as on the Haynes/Chilton’s -<o></o>
RH Cam is one tooth (8,57°) after 12 o’clock, from the straight surface from the Cylinder head<o></o>
<o></o>
So I got two have right descriptions, trusted the Ford Manual and the Truck is running pretty good.<o></o>
<o></o>
I’m still not 100% sure. Could be that the Haynes/Chilton Descriptions are correct and the RH Side should be at 12 o’clock, but I will not touch the Engine again just for testing.
<o>
</o>
Old 03-09-2013, 11:22 AM
Hi,
catching this old thread because I got a cracked RH Cylinder Head (Cyl.1) now.
I'm still not sure if the RH Head have to be set on 12 o' Clock.
But I can imagine that for the Windsor Engine maybe both descriptons are right.
What I want to say is, if you fold the Chains for the LH Head you can set the bright (or the slot) links to the marks on Cam and Crank - result = 11 o 'clock.
But for the RH you can set a Bright link to the Crank and a Slot to the Cam Mark (this would result that the RH would be at 12 o`clock and not one tooth (8,57°) after 12 o’clock.
Think my problem is, that my chains don't got this copper marked links.
Would be very appreciated if someone can tell me how many marked links are on this chains? Maybe 2 for the LH Side and 3 for the RH (this would make everything clear)?
And what do you think about the 12 o'clock position? 100% right or just a kind of close to be 12 o'clock.
I asked several mechaniks and they all not 100% sure (okay they don't work much on Modular Engines)
Thank you and have a nice weekend,
Monaco
Old 03-13-2013, 12:58 PM
Question Timing Windsor Vin: 6 Modular Engine
No one?
Old 04-02-2013, 03:52 AM
Okay Guy's, think I found out how it works!
And on a 1997 Windsor NPI Head 2Valve Engine are only two Marks on the Chains, and this means, that the description from "Racerguy" are not for the 1997 2Valve Engine (maybe for the 3Valve!!??)
Hope you can see the pictures or just klick on the links:
2 WindsorTiming RH Cam 8,57° in front of 12 o Clock 002.jpg - Timing a 1997 Ford Windsor 4.6 - Meine Album Website
And here the link to the cracked Heads Album:
http://mustang2.magix.net/album/alle-alben/!/folder/2742416
rough Idle and vibration in steering wheel rickfar Escape & Escape Hybrid 6 02-12-2014 06:42 AM
Need help...can't get this thing to idle (long) compman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-22-2013 10:23 PM
2003 f150 4.6 high idle, ludging and hard shifting manchu76 Modular V8 (4.6L, 5.4L) 2 07-12-2013 03:05 AM
want my truck back to normal!!! almonyspm1 1987 - 1996 F150 & Larger F-Series Trucks 4 06-20-2013 12:06 AM
'04 Explorer Idle... Low? tyguy Explorer, Sport Trac, Mountaineer & Aviator 1 04-09-2006 08:56 PM
Tags
1997, 2001, 350, 46, 97, chain, f150, idel, idle, installation, low, marks, problem, slow, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
