Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-08-2012, 01:15 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
anybody else using a vacuum guage?
I have been using one for a little while now and am curious as to what some other people are getting for readings during acceleration, cruise at various speeds, etc.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #2 (permalink)
Old 04-09-2012, 09:20 AM
jimandmandy jimandmandy is offline
Garage is empty, add now
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Are you using one that reads in inches or mm of hg like a manifold pressure gauge, or psi, like a turbo boost gauge?
  #3 (permalink)
Old 04-09-2012, 09:57 PM
1984 Ford Bronco
mine reads in inches
__________________
  #4 (permalink)
Old 07-19-2012, 11:01 AM
logman7777 logman7777 is offline
logman7777 is starting off with a positive reputation.
I have used a vacuum gauge with a Air/Fuel Ratio gauge to maximize my mileage but since I just bought my Ranger I dont have any baseline numbers yet.
  #5 (permalink)
Old 07-31-2012, 07:27 PM
1984 Ford Bronco
i would be interested in comparing numbers. granted I live 5000 feet above sea level. but my 88 pulls 17" at idle (not uncommon around here) cruising in 4th at 55 it sits at 10", and at 65 in 5th it pulls 7". if i wind it up to 75 it only pulls around 4". I'm worried that by then im tapping into the acceleration circuit. making me waste even more fuel.
__________________
  #6 (permalink)
Old 08-01-2012, 09:54 AM
Did the 88 not come with factory EFI? I thought that by then all Ford light duty engines were bank-firing MAP-controlled EFI. Anyway, if it is carb'd, it it high-altitude calibrated emissions? If not, it may be opening up the power valve at four inches and wasting fuel.
Im at 6000ft MSL, but had EFI on everything starting with the '88 Ranger.
  #7 (permalink)
Old 08-01-2012, 10:39 PM
1984 Ford Bronco
yeah, its efi, but even efi has a "power enrichment circuit" similar to a power valve, it goes into open loop and feeds a specified mixture instead of listening to the o2 sensor. I know it does it with your foot on the floor, but i'm not sure where it would kick in as far as vacuum goes.
__________________
  #8 (permalink)
Old 08-02-2012, 09:51 AM
So, enrichment it may be triggered by manifold pressure (aka vacuum) or throttle position. Both are sensor inputs to the PCM. We just dont know which one.
Tags
150, 1984, gadge, mercury, psi, pump, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
