Differences of frame width '96 and '04? - Ford Truck Enthusiasts Forums
Old 04-07-2012, 09:35 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Does anyone know the differences in frame widths between the older '96 frames and the '04 frames? I have access to a receiver hitch from a newer truck but the width seems a little narrow for my '96. I have access to fabrication shop but I do not want to create a frankenstein hitch...minor bends and welds are fine.
Thanks!
Leo
Old 04-07-2012, 10:17 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Just buy the correct hitch for the truck. Cutting/bending/welding to make that hitch fit will significantly weaken it.
Old 04-08-2012, 11:17 AM
LeoJr's Avatar
I found new kits for under $300. A used one in need of some sort of fab will cost about $100. Unless I find the correct used one cheap, I'll take the easy way and buy new.
Thanks!
Old 04-08-2012, 11:19 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
NEVER compromise when it comes to a hitch.
Old 04-08-2012, 11:36 AM
CletusSnow's Avatar
CletusSnow CletusSnow is offline
CletusSnow is starting off with a positive reputation.
If the hitch is truly from an 04 and not any newer, it will fit your 96. If it was an oem one, it may not because of bolt hole locations. However, any aftermarket hitch you would buy for your truck, that part number also fits f250/350/SD up to 2004.
Old 04-08-2012, 11:48 AM
kd0axs's Avatar
Quote:
Thanks!
$300?!?!
Here's one for $128 with free shipping, says it includes a ball mount insert too.
80-96 Ford F100,F150,F250,F350/97 F250,F350 HD Pro Series Trailer Hitch 51009 | eBay
Old 04-08-2012, 12:10 PM
LeoJr's Avatar
[QUOTE=CletusSnow;If it was an oem one, it may not because of bolt hole locations. However, any aftermarket hitch you would buy for your truck, that part number also fits f250/350/SD up to 2004.[/QUOTE]
The used one I found for $100 is an OEM from a '04. I'm looking at the Titan 45002. I don't currently need a weight distribution capable hitch but cost wise it doesn't make sense to buy a bigger hitch later. I already have a couple of Class 5 drop hitches and adapters.
Thanks for all of the input!
F350 Cab and Chassis FordTruckGuy96 1987 - 1996 F150 & Larger F-Series Trucks 3 10-25-2015 01:43 PM
Difference in frame rail width from 72-73, or from F250 to F250 ranger? kkubina 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-03-2015 02:06 PM
04-08 vrs 97-03 frames mark_5102 2004 - 2008 F150 0 11-27-2014 10:07 PM
are the frames from the 70s different width ? roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-18-2014 03:18 PM
Frame widths k_brenner 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-13-2013 11:02 PM
Tags
0408, 1993, 1996, 96, f150, f350, ford, frame, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
