My Truck is starting to Co$t Me!
The EBPV/EBV (Exhaust Back Pressure Valve) is a solenoid that closes a valve in the exhaust housing in the turbo, creating pressure and helping heat it up a tad quicker. It is SUPPOSED to only open when idling, and below certain temps. Sometimes they leak, stick open, etc and can cause the valve to close when it's not supposed to.
You can try unplugging it (truck off/cold) and see if it goes away. It is the only electrical plug in the bottom of the pedestal under the turbo. In my (and many other's) opinions it's not really needed. It's not uncommon for people (like myself) to delete them completely in lieu of fixing them. I will upload some pics in a second.
This is the pedestal, (out obviously) The plug is the white-ish connector in the bottom right in the pic. The rod/solenoid that controls the valve is in the bottom left hand side of the pic, pointing towards the camera.
This is the actual plug itself. Just pop the clip off and pull out. Mune is just hanging in the valley tied out of the way.
This is the actual valve that closes and creates the back-pressure.
I'm not into cults...outside of PSDs and Guns, anyway!
Sounds more and more like a faulty EBV solenoid in the turbo pedestal. Does it do it all the time or only when cold? Louder in the engine compartment or tailpipe?
I'm former NYPD, Have lots :-)
Next time it does it, try tapping the brakes.
Also, check the RPMs, (are they higher than normal? goes down when you hit the brakes?) and what temps are you seeing it come on at?
Newstang, No Mac interface for AE. which sucks. I to am a recovering Windows user. Dropped Bill Gates about 2 yrs ago. got tired of having to pay $$$ every time Bill decided to rearrange the "furniture" and rename the product. I still have an old Toshiba that I run my AE on. I don't want anything Windows even near my Mac.
Barney
Barney
Precisely. I only use it for Microsoft Streets and Trips, (unavoidably necessary for work), Auto Enginuity, and DP tuner's F6 software. The nice thing is, the Windows side is totally separate from the Mac side, so if it has issues, you simply erase it and re-install it. And the ample computing power of the Mac allows one to run both systems concurrently without a hitch. Pretty cool....
#30
