Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 04-07-2012, 02:19 PM
Fordtruck51 Fordtruck51 is offline
Garage is empty, add now
Fordtruck51 is starting off with a positive reputation.
1963 brake cylinder
PLEASE HELP!!!! I'm having problems with my 63' f100. I have read every thread on master cylinder swap but cannot find anyone that says what master cylinder from what car I can swap out to use on my 63' iam going to put disc brakes on soon but my master brake cyl. Is leaking and dripping on my foot and I have to pump the brakes to stop. I know not safe. Thanks for any info.
  #2 (permalink)
Old 04-08-2012, 09:48 AM
pburress's Avatar
pburress pburress is online now
1963 Ford F-100
pburress is starting off with a positive reputation.
same here
I have the same issue on my '63 F100. I'm getting ready to install a power booster and since one of my front single piston cylinders is leaking, I want to replace/upgrade both front cylinders. I noticed that my rear wheels have dual piston cylinders. Those are working fine so I will just be changing out the front.
EDIT: Oops, just realized you are talking master cylinder and I am talking wheel cylinders. Sorry for the thread hijack. FWIW, you could consider the same power brakes upgrade which includes a dual master cylinder. It is $300 and is sold as completely bolt on, no mods necessary. http://www.classicperform.com/Store/...ck/4852BBD.htm. I have opted to do this first, instead of the front disk upgrade. I'll see how it goes and can always go to front disks later.
  #3 (permalink)
Old 04-09-2012, 08:28 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Just about any master cylinder of at least 1 inch diameter will do. Any ford car or truck up till now...
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #4 (permalink)
Old 04-29-2012, 10:46 PM
I took a master cylinder off a 86 ford ranger. Did not have the power booster just the M/C got all the brake lines on with the new plumbing on today. Works great. Bolted right on just had to cut the rod down about a 1 1/2" down and it all bolted on now I need to figure out the brake lights
Tags
1962, 1963, 61, brake, cylinder, econoline, f100, ford, installing, master, parts, rear, truck, unibody, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
