1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Keyless Entry
Old 04-07-2012, 01:28 PM
manny83107's Avatar
manny83107
manny83107 is offline
Keyless Entry
i have a truck that was bought used and it didnt come with the code for the keyless entry. where can i locate the security module that has the code to reset it? it is a '04 f250 .
Old 04-07-2012, 03:33 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
The code (5 digits) is on the keyless entry module, which is mounted on the firewall behind the radio. On my 05, I was able to see it by opening up the drivers side glove box, but 04 doesn't have that. You might be able to see it if you stick your head under the dash and shine a flashlight up there, otherwise you will probably have to pull out the radio to see it.
Also, it's not a code to "reset" it. The code on the module is the code you use to unlock the doors.
Old 04-07-2012, 05:41 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Once you have the code, you can set your own personal code to something more easily remembered.
Old 04-07-2012, 06:03 PM
manny83107's Avatar
manny83107
dcchamberlain, where can you access the module from on your '04? kd0axs reply cant help me because there isnt a glovebox by the driver side on the '04
Old 04-07-2012, 06:10 PM
dchamberlain
It helps to be a contortionist. While standing on your head, with your legs draped over the seat back, look up from under the dash towards the center of the forward firewall. You'll need a light. Way up at the top, hidden behind some insulation is a box. I don't remember if it's white or black, but it has a sticker on it with a bunch of numbers. The 5 large numbers are the code.
If that doesn't work, get the radio removal tools and pull out the radio. The box is behind it, hidden behind the insulation. It might not be directly visible, I have heard some people use a mirror.
Old 04-07-2012, 06:49 PM
manny83107's Avatar
manny83107
thanks guys
forzas
1997-2006 Expedition & Navigator
03-06-2016 03:18 AM
BigPapi
11-22-2009 03:12 AM
cmarrero76
02-07-2007 12:43 PM
scootergsxr03
2004 - 2008 F150
10-25-2006 02:05 PM
Super Steve
03-09-2005 07:59 AM
Quick Reply: Keyless Entry
