Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-07-2012, 09:01 AM
carlsson carlsson is offline
1999 Ford F-250
carlsson is starting off with a positive reputation.
Bosch replacement fuel pump
Has anyone else replaced their fuel pump with the bosch 69131 unit? I am trying to replace a Motorcraft pump assembly that failed after two months of service, so I decided not to buy another for $300+ and got the bosch unit for $70. The problem is I cannot seem to mount it correctly inside the assembly as it is not identical to the original. It has two separate rubber spacers, both of which leave the pump loose inside the old pump housing (and therefore the fuel line on top does not completely engage the outlet of the pump. The rubber spacer from the original unit cannot even fit on the bosch unit because they are slightly different sizes so that is not an option. Any help from someone who has used the bosch pump would be greatly appreciated.
  #2 (permalink)
Old 04-07-2012, 12:15 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
2000 Ford F-250
My Garage
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Why don't you contact the pump supplier for installation manual?
All forum advise is going to be generic, not likely applying to unknown pump model
  #3 (permalink)
Old 04-07-2012, 12:16 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
Garage is empty, add now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
What engine and year?
The Bosch parts catalog specs a 69135 (w/ bracket) or 69136 (w/o bracket) for the 7.3L diesel, and a number of different parts for the gas engines, but none of them are 69131.
Vehicle Part Finder
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #4 (permalink)
Old 04-07-2012, 03:05 PM
1999 Ford F-250
Yes,69131,it is in bosch website and napa auto parts for 99w 5.4.
Tags
2000, bosch, f150, fuel, good, pump, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
