1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
front driveshaft in 2wd?
Old 04-06-2012, 09:30 PM
cbzdel's Avatar
cbzdel
cbzdel is offline
I have always had manual transfer cases before. now my f250 had esof 4x4. I noticed when my wife was moving my truck that the front driveshaft turns in 2wd. I swear I remember my manual t-case rigs not doing this. Just trying to figure put what is normal..
Old 04-07-2012, 01:58 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
It depends on what has the most drag on it...
While there is nothing making it turn, there is nothing preventing it from turning either. Can you turn it by hand while the vehicle is in 4x2?
Old 04-07-2012, 08:41 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
check the hubs and see if they are in auto or locked position.
If in auto then they really should not be turning until you turn your 4x4 switch.
They may move a bit but not at the same speed as if in 4x4.
Get down the see if you can manually turn the shaft and at the same time like at your axle shafts and see if they are turning.
Old 04-07-2012, 12:15 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
sometimes based purely on friction the front driveshaft can freespin.. but it wont be at the same speed the rear shaft is turning.
Old 04-07-2012, 03:45 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
The front driveshaft will lazily rotate in 2wd. This is just due to friction in the system. However, it should not spin at fill speed. This can happen when the hubs do not disengage.
Crawl under the truck and try to spin the front driveshaft. If it freely spins then you are okay. If it wont spin freely your hubs did not unlock (some side to side play is expected, even if locked). Once you have done this, cycle the hubs from LOCK to AUTO (Unlocked) and try it again. Often times this will do it. If its still locked, cycle one more time, and back the truck up 10 feet. Again this almost always fixes it (temporarily).
To solve the problem you need to service the hubs. Guzzle has a write up on that:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Here are two videos showing the drive shaft in both the stuck and free states.
4x4 Front Driveshaft (Hubs Stuck) - F250 7.3L Powerstroke - YouTube
4x4 Front Driveshaft (Hubs Fixed) - F250 7.3L Powerstroke - YouTube
Old 04-07-2012, 09:53 PM
bpounds's Avatar
bpounds
bpounds is offline
I like to turn my wheels all the way to one side, doesn't matter which side, and reach in on each side and grab the axle U-joint and see if it will turn by hand. This tells you that the locking hub on THAT side is unlocked. Every owner of an ESOF truck should learn to do that, because sooner or later you are going to have hub problems.
Remember that one hub can fail and be locked, and the front driveshaft will still turn by hand, because the diff is an open unit. This is why you want to check each side individually.
Old 04-08-2012, 12:59 AM
cbzdel's Avatar
cbzdel
cbzdel is offline
Ok I tested it, my front drivrshaft will not spin in 2wd.. I checked the hubs they are in auto.. I didn't have time to turn the wheels and play with ujoints, but as I was lazing I asked my wife to look and it was turning the same speed as the rear one.. I tested the system in 2wd and gassed it in lose dirt and just the back wheels spun, I put in it 4wd and gased it and I couldn't ged the wheels to spin, I could feel the traction from the front wheels working, took out back to 2wd and the **** easily spun..
What's the deal? I will mess with the ujoint tomorrow, as I am also installing my new fog lights
cmjenkins
Modular V10 (6.8l)
01-27-2010 08:55 PM
fordboy2
04-12-2008 03:49 AM
villestrip
05-04-2007 05:39 PM
Bob Jusnes
1978 - 1996 Big Bronco
08-18-2006 03:19 PM
slickwillie
1997-2006 Expedition & Navigator
17
03-25-2005 05:40 PM
Quick Reply: front driveshaft in 2wd?
