06 f450 6.0 no start no crank - Ford Truck Enthusiasts Forums
Old 04-06-2012, 08:10 PM
skylinetowing skylinetowing is offline
skylinetowing is starting off with a positive reputation.
i got a new ficm that was already program i put it in my truck and started up just fine drove for about a hour and the truck shut off on me. the check gauges light came on the wrench light came on and the abs light came on tried to restart the truck but it wont even crank can someone help me please
Old 04-06-2012, 08:12 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
Sounds like a power issue
that ABS Light likes to come on when its got Low Power Condition present
What codes come up??????
What do you mean no crank????????
The starter will Not Engauge period
or
starter works but truck will not run
Old 04-06-2012, 08:27 PM
The starter isn't doing anything. I jumped the starter from under the truck and cranks that way but not when u turn the key. The injectors don't even buzzs
Old 04-06-2012, 08:44 PM
BLADE35's Avatar
Gottcha
So that might be a Fuse or bad Relay maybe bad ignition switch IDK
Are the FICM Pluggs fulley seated you probably already checked those???
Auto Trans???
Old 04-06-2012, 08:49 PM
All the plugs and in the ficm checked the fuse they are good I am going to replace the relay and see what happens I am going crazy
Old 04-06-2012, 08:52 PM
BLADE35's Avatar
Does the fuel pump run when you cycle the key to on
or is it dead to
Old 04-06-2012, 08:54 PM
No I didn't hear it
Old 04-06-2012, 09:14 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Wouldn't hurt to stick a code reader on it to see what comes up. I'd also check the following fusees:
#20 - FICM
#27 - ING Switch (Run Feed)
#45 - ING Switch (Run/Start Feed)
#103 - ING Switch (sends power to the FICM)
#110 - ING Switch
#116 - ING Switch
Mine popped #45 a couple of days...gauge cluster went dead. The only way I found it was with a DVM.
Old 04-06-2012, 10:14 PM
BLADE35's Avatar
Quote:
#20 - FICM
#110 - ING Switch
#116 - ING Switch
Now were getting somewhere
Man I have been wondering where a List or schematic was that shows all those fuses I guess the one under the dash should be labeled
Are the Black Boxes driver side engine compartment labeled
I have just been wondering about them recently
Old 04-06-2012, 10:22 PM
All I know is this crazy so far all the fuses are good I was think can it be something with the programming with the ficm ? They didn't program it was preprogram
Old 04-06-2012, 10:51 PM
zhilton's Avatar
I need/meant to add this...when mine popped #45 it started and ran just fine. I just didn't have any OEM gauges. And I couldn't turn the Tow/Haul mode on. I checked all the gauge cluster fusses without much luck. It was with the help of the DVM that I found #45 was blown, replaced and everything is well at the moment.
Quote:
(Cough, owners manual has the complete list)
I think I know which box your talking about...forward/below the master cylinder? That's the only box that looks like it could have relays in it. I know there's a bunch of engine related circuit breakers/fuses in the box ahead of your left knee in the cab.
I'm thinking it wouldn't start in the first place if the FICM hasn't been programed. Maybe it's time to bring the professional in...Ed at FICMrepair.com (I'll see if I can get his attention). Either way, if it started drove fine for a while then just died and won't do anything now...I'd check connections before I assumed the worse/most expensive route.
Old 04-06-2012, 10:58 PM
It was a pre programmed but not from my old ficm my gauges were working
Old 04-06-2012, 11:18 PM
BLADE35's Avatar
I have a couple files on this computer that are Labeled 6.0L Owners Guide #1&2
Neither one has that schematic just a Breif section on fuses and if they burn out continusly you got problems just went threw it again not what I wanted
I Heard there in the owners manual just wondering what I have is Diffrent IDK
Maybe theres an owners manual in the glove box IDK have to check it out
I was just hoping there was something on here guess I just need to download the repair Manual from Motocraft site wanted a better wire diagram anyway the one in the tech folder leaves alot to be desired better than nothing though
Old 04-06-2012, 11:26 PM
BLADE35's Avatar
I think I know which box your talking about...forward/below the master cylinder? That's the only box that looks like it could have relays in it..
Yes that box has relays and I know theres a FICM Fuse in it shows up when going threw that FICM Guide but only points the one FICM Fuse out
Just wondered about the other ones
To OP Id do just like Zach says and take a DVM to those fuses some can look good and not pass Continuity test
Also the PCM and stuff is kinda in that master cylinder area wheel well area wonder if you bumped a wire harness when installing that FICM
Old 04-06-2012, 11:59 PM
I got my ficm from Midwest injectors it a alliant power ficm are they any good?
68 F100 Issues Cranking Hwklein88 1967 - 1972 F-100 & Larger F-Series Trucks 6 11-03-2016 05:44 PM
f350 5.4 no start no crank nonpower jwiowa 1999 to 2016 Super Duty 3 02-14-2014 09:46 AM
My NEW no start situation. HKusp 1999 - 2003 7.3L Power Stroke Diesel 166 02-06-2014 08:54 AM
P.O.S Diesel Dieseldriver13 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-27-2013 12:46 AM
Rebuilt FICM, replaced FICM harness got P0198 code cleaned plugged back in now won't start! Jbru167 6.0L Power Stroke Diesel 2 03-02-2012 02:05 PM
Tags
06, 2003, 450, 60, alliant, bad, crank, engine, f450, ficm, ford, lock, power, review, start, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
