My A/C on life support - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-06-2012, 07:19 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
This is the first time I've ever had to work on my A/C. My high side line started leaking at one of the crimps
I'm pulling a vacuum now I know the low side should be around 40-50 psi but what should the high side be no more than?
Old 04-06-2012, 07:31 PM
fordpride's Avatar
Glenn your bad luck is running down this way you can have it back are send it to Darin. lol
Old 04-06-2012, 08:05 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Hey Mike, I don't want it too bad, I seem to have enough of my own!
AC work I leave to someone who knows what the %^&* he is doing. Good luck with that, I'm not that person..
Old 04-06-2012, 08:08 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is gaining momentum as a positive member of FTE.
Your High side is going to vary quite a bit depending on how hot the air going through the condenser is. it wont go beyond what the high pressure switch is set for. The system will have stopped cooling by that time though. At 60deg F it will have a vapor pressure @ 57.5 PSIG. At 95 it will be 114 psig that doesnt include heat from compression dirty condensers and such. This chart will help you work on your A\C system successfully.
it also occurs to me that the auto store cans of 134 have a nice gauge to at least get you close so i wouldnt worry about over charging it. stick a thermometer in the vent while its charging so you can see that point when its at its coldest.
Old 04-06-2012, 09:07 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Dang mike I feel your pain. Since I've owned my truck the AC would make you put a sweater on. This year nothin. I haven't even begun to trouble shoot it yet, just like Ohio, 80 one week, 50 the next...
Old 04-06-2012, 09:10 PM
fordpride's Avatar
HS is between 110-220
LS is beteen. 25-55
My vents are getting down to 35*
Old 04-06-2012, 09:11 PM
fordpride's Avatar
In Louisiana your a unhappy camper without A/C
Old 04-06-2012, 09:40 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
I bet the humidity is a killer down there!
Old 04-06-2012, 10:05 PM
fordpride's Avatar
When full summer hits you can walk out the door at 5:30am and it 85* and 95% humidity
Old 04-06-2012, 10:11 PM
ReBilld's Avatar
I can take the heat, but that kind of humidity would kill me. It's bad enough here!
Old 04-06-2012, 10:12 PM
fordpride's Avatar
Yea by time you get out the door and make it to your truck the sweat is starting to run down you forehead
Old 04-06-2012, 10:16 PM
ReBilld's Avatar
I hope you get your A/C fixed.....if not you'll melt!LOL!!
Old 04-06-2012, 10:17 PM
fordpride's Avatar
It's fixed and blowing cold
Old 04-06-2012, 10:24 PM
ReBilld's Avatar
Oh yeah.....I see that post now, missed that. Well good deal, I was starting to sweat for you!
Old 04-07-2012, 12:54 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
LS is beteen. 25-55
What were you saying about bad luck?? Looks like both of ours got better! Glad you got it fixed, I've always said that if the cruise and ac don't work they are going to be fixed right away.
I like free beer fordpride Testing..... 36 12-26-2016 12:29 AM
I got new parts fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 35 06-21-2015 10:24 AM
08 front bumper on a OBS fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 22 06-03-2012 11:14 AM
Added a billet grille fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 23 11-06-2011 02:40 PM
Trans voltage fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-07-2011 09:58 PM
Tags
12, 1999, ac, chart, f250, low, nitrous, oxide, pressure, pt, r134, specs, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
