My A/C on life support - Page 2 - Ford Truck Enthusiasts Forums
Old 04-07-2012, 07:52 AM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Quote:
Originally Posted by fordpride View Post
It's fixed and blowing cold
What was the problem, just need recharged?
Old 04-07-2012, 08:35 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Quote:
The HS line started leaking at one if the crimps
Old 04-07-2012, 10:52 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I have one of those vac's, its been along time sinse I used it. How long do you run it?
Old 04-07-2012, 01:37 PM
fordpride's Avatar
I ran it for 1 hour
Old 07-03-2012, 11:58 PM
HS is between 110-220
LS is beteen. 25-55
My vents are getting down to 35*
Its been 100* here in the Black Hills and besides being chased around by forest fires my ac, which has been working good since I replaced the HS switch, is cutting out. Is my system overcharged according to your figures above Mike? It doesn't make sense to me for it to be overcharged. If you guys (Mike) don't see this I'll start a new thread but sometimes old threads get more attention.
Old 07-04-2012, 12:01 AM
fordpride's Avatar
Normally when the HS gets too high is cause of a blockage.
Was that with the AC an max?
Old 07-04-2012, 12:02 AM
fordpride's Avatar
The HS shouldnt get over 250
Old 07-04-2012, 12:38 AM
Great, not what I wanted to hear. I don't have the vac with me, darn it. Those reading are at max, high idle and after about five minutes of running. I pulled the camper about 20 miles and it would only work when not under a heavy pull. When stopped it would click on and off. After about a hour it would stay running and that's when I put the gauges on.
A little side note, I couldn't get the HS fitting on and was at a loss as to way. I finally figured it out, when I took the cap off the plug inside stayed in the valve and left a hole in the top of the cap. I used a needle point from a light tester, a little bit of light drilling and got it out. Then after I put the gauges away and walked back to the truck I heard it leaking. Put the gauges on again and took the picture. The first time I had them on the HS was up to 340 so I guess I have a blockage.
Thanks for your help Mike. Would that reading be OK because I was using high idle??
Old 07-04-2012, 12:42 AM
fordpride's Avatar
When I did mine I had it in high idle and it never got over 225
Old 07-04-2012, 12:43 AM
fordpride's Avatar
When the HS gets to hight it will shut the compressor down to prevent damage
Old 07-04-2012, 01:00 AM
OK, thanks. After 205K its time for a overhaul.
What usually gets blocked, is it a little screen in there, seems like I read that?
Old 07-04-2012, 01:20 AM
fordpride's Avatar
Orifice tube could be stopped up but if it the orifice is stopped up that means debris came from somewhere.
The last one I seen clogged was cause of metal shavings coming out of the compressor
  #28
Old 07-04-2012, 01:34 AM
fordpride's Avatar
Ambient temp
100F
Low side
40-50 psi
High side
200-250 psi
Center vent temp
52-60F
  #29
Old 07-04-2012, 01:35 AM
fordpride's Avatar
  #30
Old 07-04-2012, 01:41 AM
Tried to rep you but.... Looks like a good article, to beat to read it now. Thanks Mike!!!
I like free beer fordpride Testing..... 67 02-11-2017 06:33 AM
I got new parts fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 35 06-21-2015 10:24 AM
08 front bumper on a OBS fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 22 06-03-2012 11:14 AM
Added a billet grille fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 23 11-06-2011 02:40 PM
Trans voltage fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-07-2011 09:58 PM
Tags
12, 1999, ac, chart, f250, low, nitrous, oxide, pressure, pt, r134, specs, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
