Fuel gauge not working after new pump installed. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-06-2012, 05:11 PM
conorreich's Avatar
conorreich conorreich is offline
conorreich is starting off with a positive reputation.
I own a 1990 Ranger 2.9l and about 4 months ago the fuel pump went bad. I had one installed at a local mechanic shop. When I got it back from them the fuel gauge had stopped working. I would've brought it back but I was ripped off (charged 700$) for a fuel pump install, so I have no interest going back there. I have replaced minor components (water pump, serpentine belt) and have electrical experience. Any ideas?
On a side note this is my first standard as well as my first ranger and so far (besides the problems any 22 year old truck would have) I love the little monster!
Old 04-06-2012, 07:55 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Wow that sound a little high. What kind of pump did you have installed? I haven't replaced a pump on a ranger but I know it is attached to the pump assy. The shop should be eating it. You could give them a call and see what they say about it.
Old 04-06-2012, 08:44 PM
conorreich's Avatar
It was a bosch I believe. It was the only pump the shop would install. I completely agree but I've already raged on that shop once. I'd rather get it done myself.
Old 04-06-2012, 10:56 PM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Either they forgot to connect the wire that feeds info to the gauge or the wire was broken (by them) when the pump was replaced. Do you know if they removed the bed to replace the pump? If so, it should be a fairly easy job for you to remove the bed and check the wiring.
Old 04-07-2012, 08:45 AM
conorreich's Avatar
As far as I know they did remove the bed. I guess I should rig up a new filler neck as well. Anybody have any tips on removing the bed? This is greatly appreciated guys, thanks.
Old 04-07-2012, 08:59 AM
michigan66's Avatar
The bed is held in place with six bolts. The bolt heads show in the truck bed. Remove them. Then lift the bed enough to get to the top of the tank. You don't have to remove the bed completely. Oh yes, disconnect the filler pipe at the bed connection before lifting it.
Old 04-07-2012, 11:01 AM
conorreich's Avatar
I'll see if somehow I can get this done by myself today otherwise I'll have to buy some Guinness and get a buddy of mine over. I'll post my results. Thanks guys!
EDIT:Pulled the bed off with the help of my brother and cleaned the contacts on the fuel pump. The fuel gauge is doing more than before, but I won't actually know until I run for a week or so. Thanks guys for all the help. I should've come here sooner. I could have saved 700 bucks!
fuel lines question brk300 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-01-2016 09:37 PM
Fuel Pumps are dying. Holmesuser01 1987 - 1996 F150 & Larger F-Series Trucks 10 05-15-2015 08:50 PM
98 2.5 fuel pressure good but jumping? 1998Ranger25L153CID Ranger & B-Series 3 04-21-2015 01:20 AM
Fuel System Problems.... HELP! Alec94F150XL 1987 - 1996 F150 & Larger F-Series Trucks 7 07-28-2011 08:34 AM
2004 Ford Ranger Tremor Fuel Pump Problems or Someting Please Help!!!! dffdixie Ranger & B-Series 19 09-11-2009 12:02 PM
Tags
90, engaging, escape, f150, ford, fuel, gage, gas, gauge, installed, pump, ranger, stopped, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
