Manual trans fluid. - Page 2 - Ford Truck Enthusiasts Forums
Manual trans fluid.
Old 11-14-2012, 12:36 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
I would not run ATF. Just too thin for a manual tranny and not much antiwear additive. My '95 F150 never shifted right until I ran the next thicker fluid, which would be a syncromesh fluid. My choice is Redline MTL, which has tons of antiwear additive. Shifted beautifully with MTL.
Old 12-03-2012, 03:56 PM
TallPaul's Avatar
Quote:
ATF fluids contain a specific additive package for Automatic Transmissions, and not for manual transmissions. Most ATF specifications for use in mtl's, IMHO, were to improve cold weather shifting, and not to improve wear.
The above quote is from someone who had blended oil and transmission fluid (I actually ran his fluid in the F150 tranny at one time): Quote is from 5th post here.
Old 12-04-2012, 12:53 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The Getrag 5-speed in my old BMW could take ATF, straight-30 motor oil or 80W gear oil according to the owners manual. Mercedes owners have told me their cars manual transmissions were also not picky. Redline MTL is what I settled on.
Old 12-04-2012, 02:16 PM
TallPaul's Avatar
Quote:
Originally Posted by FordGuy85 View Post
OK, got some coastal type f atf in the trans this weekend. So far, seems to be Working quite a bit better than before. Still not like new but very livable.
Call Redline (number is at redlineoil.com) and talk to their chemist, Dave. He is very accessible. Tell him the problem you are having with going into gears and see what he recommends. My gut feeling is that MTL would work better, but what do I know. No harm talking to him.
Old 12-04-2012, 06:57 PM
Beechkid Beechkid is online now
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Thanks for the replies! I thought it would be interesting to note that my trans has some wear. You have to be at very low speed or stopped to go into second (I take off from a stop in second). Sometimes it will grind a little when I turn at low speed trying to get it into second. This is a grey area because a lot of the times I am not moving fast enough to use 3rd gear in some turns. Any additives? Certain brands? Lucas? Royal purple? I am thinking ill probably just go with the motorcraft but I'm hoping like heck there is something better for my tranny with some wear.
That would be worn syncro rings.....
Old 12-04-2012, 08:16 PM
TallPaul's Avatar
Quote:
As the Type F being less slippery seemed to help, so also would not a thicker fluid also help?
Old 12-05-2012, 09:45 AM
A common problem with older transmissions was that the sychros were made from brass or bronze. 80W-90 gear oil was the common recommendation. This was not optimum, but worked ok with the old API GL-4 and earlier oils. Now, GL-5 EP hypoid oil is all that is commonly available in that weight. GL-5 contains a higher dose of sulphur-based additive (the stinky stuff in gear oil) to better protect rear axle gears . It also corrodes yellow metals, making the syncros go away. This is not a problem in non-synchronized heavy duty truck transmissions, so these oils also get the API MT-1 designation. People mistakenly think MT-1 means its safe for all manual transmissions.
This debate rages on old Volkswagen forums because those cars have the transmission and differential in a single housing. What is specified in the owners manual sometimes doesnt exist, so people believe newer specs are always backward compatible. Since the ring and pinion gears are spiral bevel, like pre-1950's Fords, not hypoid, EP gear oil is unnecessary and in fact harmful. This is a similar issue to newer low-zddp motor oils in older flat tappet engines.
Old 05-16-2013, 03:12 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown Bad Bad Leroy Brown is offline
Bad Bad Leroy Brown is starting off with a positive reputation.
After running the Pen syncromesh for about 7 months, I decided to go thicker because I still had a good amount of whine in gears 1 through 3 but shifting was much better compared to any ATF.
This may be controversial, but I just put in Redline MT-90 which is a GL-4 synthetic manual trans oil with the viscosity of 75w-90. Shifts even better than the syncromesh and doesn't feel "too thick" at all. Plus it is very good for the yellow metal syncros, and has a just right coefficient of friction to make them work when shifting.
The Pennzoil came out dark in that short time, so it may be too harsh of an environment for it making it oxidize, the redline should be able to handle the heat better. Time will tell if its too thick for winter shifting, but I'll use it until I run into any issues.
Old 03-04-2014, 07:45 PM
Grant Harvey Grant Harvey is offline
Grant Harvey is starting off with a positive reputation.
thicker fluid in winter?
So how did that thicker fluid work for you in the winter months?
Old 03-08-2014, 06:55 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
pennzoil syncromesh work fine for me in winter, i wouldnt run any heavier oil than that in a manual trans unless it called for it.
Keyless Keypad Code xTraveler Excursion - King of SUVs 746 02-11-2017 11:29 PM
Keyless entry code (instructions and string) robert_l_ross Excursion - King of SUVs 81 08-31-2016 09:02 AM
wanted stock wheels '54 f100 16x4.5, 5on5.5 stock54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-30-2015 06:13 AM
Wheel Hub Measurements oldracerjones 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-01-2015 08:39 PM
Tonneau covers REDFORDFX4 2009 - 2014 F150 5 03-20-2010 10:25 AM
Tags
2002, 77, e99, f150, f250, falls, fluid, ford, manual, penzoil, sioux, synchromesh, trans, transmissions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
