Fuel Pump Vacuum Leak - Ford Truck Enthusiasts Forums
Old 04-06-2012, 09:12 AM
nanuke1's Avatar
nanuke1 nanuke1 is offline
nanuke1 is gaining momentum as a positive member of FTE.
I need to cycle my starts each day two times and wait until the fuel pump has finished its cycle to get a good start. Can the fuel pump have a vacuum leak but not leak fuel? It's much worse in cold weather but still requires two cycles of fuel pump before starting well even at 40 degrees.
Old 04-06-2012, 10:48 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Have you checked FICM and batteries?
Old 04-06-2012, 02:37 PM
nanuke1's Avatar
Batteries are 1 year old and the FICM was checked about 18 months ago. Probably worth checking again if that is a suspect part. Truck has 205,000 miles on it.
Old 04-06-2012, 11:24 PM
jonwayneking jonwayneking is offline
jonwayneking is starting off with a positive reputation.
hard starting
I having the same problem. Did you find out what it was?
Old 04-09-2012, 10:41 AM
nanuke1's Avatar
Not yet, however, I did check both batteries over the weekend and found one battery post on positive pole of battery/drivers side that was pretty corroded. I cleaned it and will check starting with one cycle of key to see if it had any effect. I do know from past experience that my truck does not start well without fully charged "healthy" batteries.
Old 04-09-2012, 10:43 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Almost sounds like my truck when the glow plug controller went out this winter.
Old 04-09-2012, 11:10 AM
Kinda skipped your question on the first post, sorry. I've read a few posts where maybe air was leaking back into the filter housing after shut down but didn't leak fuel when running. I guess it could happen but I've never had that problem.
Old 04-09-2012, 03:02 PM
nanuke1's Avatar
Truck seems to start better after cleaning the dirty battery post. This morning(30 degrees) I started with just one cycle of the key and it started just fine. Maybe a fluke? Are these engines sensitive to a minor drop in battery starting power? I'll keep monitoring it. I have had FICM, glowplugs, injectors, etc.. all checked and good.
Old 04-09-2012, 03:16 PM
Good batteries make a big difference. The alternator isn't puttin out till the glowplugs go off and they stay on much longer than the dash glowplug light. So it's runnin off the batts for the first min or three.
Old 04-09-2012, 03:42 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Quote:
Hmmm, sounds like a possible HPO leak. Got a gauge?
Old 04-09-2012, 04:59 PM
Maxium4x4's Avatar
Quote:
Not disagreeing but usually the HPO will show when hot.
ESOF Vacuum Leak where? Blue7.3 Australia Chapter 21 08-12-2015 11:19 PM
Fuel pressure problem captcaseyb 1987 - 1996 F150 & Larger F-Series Trucks 18 10-14-2014 02:36 PM
Fuel pump issues 97 250 HD gas BakersF-250 1987 - 1996 F150 & Larger F-Series Trucks 5 02-10-2014 09:38 AM
Trying to diagnose the two pump fuel system junkyardjeff Fuel Injection, Carburetion & Fuel System 1 11-01-2011 07:32 PM
Vacuum pump stays on Dieselman929 6.0L Power Stroke Diesel 7 11-19-2007 07:48 AM
Tags
2007, 60, 94, dakota, empty, f250, feul, filter, ford, fuel, leak, powerstroke, pump, vaccume, vacuum, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
